multicast streams are freezing randomly on X650
  • Problem
  • Updated 4 years ago
  • In Progress
i am facing a problem on x650, all multicast streams are freezing randomly for 5-10 sec and then start working again.
Setup:
MC Source ===> Cisco 2960 ====Trunk====> Summit X650 (Stack of 4 Switches) ====> User
Configs:
Extreme X650:
enable ipmcforwarding vlan "ENCODED"
enable ipmcforwarding vlan "GW"
enable pim snooping vlan "GW"
configure igmp snooping vlan "GW" ports 2:1 set join-limit 100
configure pim add vlan "ENCODED" sparse passive
configure pim add vlan "GW" sparse passive
enable pim
configure pim register-checksum-to include-data
Cisco 2960:
ip igmp snooping querier address 10.10.10.9
Photo of Muhammad Usman
Muhammad Usman
  • 70 Points
Posted 4 years ago
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
you could write an acl to count multicast packets[source] hitting x650.
This will be helpful to verify whether x650 is dropping traffic or not.
Example:
entry udpacl {if {
source-address 10.203.134.0/24;
destination-address 239.0.0.100/32;---------change ip based on ur network
protocol udp;
source-port 190;
destination-port 1250;
} then {
permit;
count multicastcounter;
configure accesslist udpacl ingress <trunkportinextreme>
