Multicast Issue: Erro:Kern.IPv4Mc.Error
  • Question
  • Updated 4 years ago
Create Date: Oct 11 2013 5:20PM
I am new to the Extreme networking world and am seeing some issues with multicasting
Here is the error I am seeing in the logs
<Erro:Kern.IPv4Mc.Error> Slot-3: Unable to Add IPmc vlan 8 for 3:23 s,G=ac106812,effffffa IPMC 0, unit 0 No resources for operation
I have been looking through documentation to point me in the right direction but I have found nothing so far.
(from Crosby_Tech)
Photo of EtherNation User
EtherNation User, Official Rep
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Oct 11 2013 7:44PM
what software version do use?
(from JÃ1⁄4rgen_Jaritsch)
Create Date: Oct 14 2013 1:37PM
We are running 15.3.1.4 with a mix of X450e and X440
(from Crosby_Tech)
Create Date: Oct 14 2013 3:34PM
you have 15.3.1.4 or for example 15.3.1.4-patch1-14 ?
How many IGMP senders/multicast streams do you have on those platforms ?
And very interesting is this -> "No resources for operation"
Maybe you can show us some config lines?
What shows "sh iproute reserved-entries statistics "
Jarek
(from Jaroslaw_Kasjaniuk)
Create Date: Oct 14 2013 9:00PM
 Here is what I get from sh ver
 - Image   : ExtremeXOS version 15.3.1.4 v1531b4 by release-manager
          on Mon Feb 4 19:19:04 EST 2013
BootROM : 1.0.5.6
Diagnostics : 5.10
sh iproute reseverd-entries statistics
                       |-----In HW Route Table----|   |--In HW L3 Hash Table--|
                       # Used Routes   # IPv4 Hosts   IPv4   IPv4   IPv6  IPv4
Slot  Type              IPv4   IPv6    Local Remote   Local  Rem.   Loc.  MCast
1     X450e-48t             2      0       1      0       0      0     0    104
2     X440-48t              2      0       1      0       0      0     0    104
3     X440-48t              2      0       1      0       0      0     0    104
4     X440-48p              2      0       1      0       0      0     0    104
5                           -      -       -      -       -      -     -      -
6                           -      -       -      -       -      -     -      -
7                           -      -       -      -       -      -     -      -
8                           -      -       -      -       -      -     -      -
Theoretical maximum for each resource type:
X440                       32     16      64     64     509    512   256 *  256
"e"-series                480    240     512    512    2045   2048  1024 * 2048
"a"-series              12256   6128    8189  12288    8189   8192  4096 * 8192
X650, E4G-200           12256   6128    8189  12288    8189   8192  4096 * 8192
X460, E4G-400           12256   6128   12288  12288   16381  16384  8192 * 8192
X670-48x, X670V-48x     16352   8176    8189  16384    8189   8192  4096 * 4096
X670V-48t               16352   8176   16381  16384   16381  16384  8192 * 6000
X480(40G4X)             16352   8176    8189  16384    8189   8192  4096 * 4096
X480                   131040   8192   16381  40960   16381  16384  8192 *12000
_x001B_[7mPress <SPACE> to continue or <Q> to quit:_x001B_[m_x001B_[60;D_x001B_[K
Flags: (!) Indicates all reserved route entries in use.
       (d) Indicates only direct IPv4 routes are installed.
       (>) Some IPv6 routes with mask > 64 bits are installed and do not use
           entries in the internal HW Route Table.
       (R) IPv6 hosts in external HW Route Table.
       (*) Assumes IP Multicast compression is on.
       (M) IPMC entries stored in L2 MAC Table when lookup-key is 'mac-vlan'.
Slot-1 CRES_Upstairs_x450-1.2 # sh ver
Slot-1      : 800391-00-01 1139G-80775 Rev 1.0 BootROM: 1.0.5.6    IMG: 15.3.1.4
Slot-2      : 800473-00-07 1244N-40184 Rev 7.0 BootROM: 2.0.1.7    IMG: 15.3.1.4
Slot-3      : 800473-00-07 1244N-40119 Rev 7.0 BootROM: 2.0.1.7    IMG: 15.3.1.4
Slot-4      : 800474-00-08 1251N-40197 Rev 8.0 BootROM: 2.0.1.7    IMG: 15.3.1.4
Slot-5      :
Slot-6      :
Slot-7      :
Slot-8      :
Here is some of the config
# Module devmgr configuration.
configure snmp sysName "CRES_Upstairs_x450-1"
configure slot 1 module X450e-48t
configure sys-recovery-level slot 1 reset
configure slot 2 module X440-48t
configure sys-recovery-level slot 2 reset
configure slot 3 module X440-48t
configure sys-recovery-level slot 3 reset
configure slot 4 module X440-48p
configure sys-recovery-level slot 4 reset
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1:1-50, 2:1-48, 3:1-48, 4:1-48
configure vr VR-Default add ports 1:1-50, 2:1-48, 3:1-48, 4:1-48
configure vlan default delete ports 1:1-48, 2:1-48, 3:1-48, 4:1-48
create vlan "CRES_ELAN"
configure vlan CRES_ELAN tag 10
create vlan "CRES_ELEM_IP"
configure vlan CRES_ELEM_IP tag 8
create vlan "CRES_PUBLIC_WIFI"
configure vlan CRES_PUBLIC_WIFI tag 205
create vlan "CRES_STAFF_WIFI"
configure vlan CRES_STAFF_WIFI tag 204
create vlan "CRES_STUDENT_WIFI"
configure vlan CRES_STUDENT_WIFI tag 200
create vlan "CRES_TLAN"
configure vlan CRES_TLAN tag 81
create vlan "DDC_CONTROL"
configure vlan DDC_CONTROL tag 11
create vlan "HIGHSCHOOL_IP"
configure vlan HIGHSCHOOL_IP tag 9
create vlan "HS_ELAN"
configure vlan HS_ELAN tag 7
create vlan "HS_PUBLIC_WIFI"
configure vlan HS_PUBLIC_WIFI tag 105
create vlan "HS_STAFF_WIFI"
configure vlan HS_STAFF_WIFI tag 104
create vlan "HS_STUDENT_WIFI"
configure vlan HS_STUDENT_WIFI tag 100
create vlan "HS_TLAN"
configure vlan HS_TLAN tag 80
create vlan "multicast"
configure vlan multicast tag 210
create vlan "switchmgmt"
configure vlan switchmgmt tag 2
create vlan "VideoCon"
configure vlan VideoCon tag 12
create vlan "WIRELESS_MGMT"
configure vlan WIRELESS_MGMT tag 99
configure vlan CRES_ELAN add ports 1:45-48 tagged
configure vlan CRES_ELEM_IP add ports 1:45-48 tagged
configure vlan CRES_ELEM_IP add ports 1:1, 1:6-13, 1:15-19, 1:21-24, 1:26-30, 1:32, 1:39, 2:1-42, 2:44, 2:46-48, 3:1-48, 4:37 untagged
configure vlan CRES_PUBLIC_WIFI add ports 1:45-48 tagged
configure vlan CRES_STAFF_WIFI add ports 1:45-48 tagged
configure vlan CRES_STUDENT_WIFI add ports 1:45-48 tagged
configure vlan CRES_STUDENT_WIFI add ports 1:2-5, 1:14, 1:20, 1:25, 1:33-37, 2:43, 2:45 untagged
configure vlan CRES_TLAN add ports 1:45-48 tagged
configure vlan DDC_CONTROL add ports 1:45-48 tagged
configure vlan Default add ports 1:49-50 untagged
configure vlan HIGHSCHOOL_IP add ports 1:45-48 tagged
configure vlan HS_ELAN add ports 1:45-48 tagged
configure vlan HS_PUBLIC_WIFI add ports 1:45-48 tagged
configure vlan HS_STAFF_WIFI add ports 1:45-48 tagged
configure vlan HS_STUDENT_WIFI add ports 1:45-48 tagged
configure vlan HS_TLAN add ports 1:45-48 tagged
configure vlan multicast add ports 1:45-48 untagged
configure vlan switchmgmt add ports 1:45-48 tagged
configure vlan WIRELESS_MGMT add ports 1:45-48 tagged
configure vlan WIRELESS_MGMT add ports 1:31, 1:38, 1:40-44, 4:1-36, 4:38-48 untagged
configure vlan switchmgmt ipaddress 192.168.20.60 255.255.255.0
# Module fdb configuration.
# Module rtmgr configuration.
configure iproute add default 192.168.20.1
enable iproute ipv4 compression
# Module mcmgr configuration.
enable mvr vr VR-Default
configure mvr add vlan CRES_ELEM_IP
configure mvr vlan CRES_ELEM_IP mvr-address none
configure mvr vlan CRES_ELEM_IP static group none
configure mvr add vlan CRES_PUBLIC_WIFI
configure mvr vlan CRES_PUBLIC_WIFI mvr-address none
configure mvr vlan CRES_PUBLIC_WIFI static group none
configure mvr add vlan CRES_STAFF_WIFI
configure mvr vlan CRES_STAFF_WIFI mvr-address none
configure mvr vlan CRES_STAFF_WIFI static group none
configure mvr add vlan CRES_STUDENT_WIFI
configure mvr vlan CRES_STUDENT_WIFI mvr-address none
configure mvr vlan CRES_STUDENT_WIFI static group none
configure mvr add vlan HIGHSCHOOL_IP
configure mvr vlan HIGHSCHOOL_IP mvr-address none
configure mvr vlan HIGHSCHOOL_IP static group none
configure mvr add vlan HS_PUBLIC_WIFI
configure mvr vlan HS_PUBLIC_WIFI mvr-address none
configure mvr vlan HS_PUBLIC_WIFI static group none
configure mvr add vlan HS_STAFF_WIFI
configure mvr vlan HS_STAFF_WIFI mvr-address none
configure mvr vlan HS_STAFF_WIFI static group none
configure mvr add vlan HS_STUDENT_WIFI
configure mvr vlan HS_STUDENT_WIFI mvr-address none
configure mvr vlan HS_STUDENT_WIFI static group none
configure mvr add vlan multicast
configure mvr vlan multicast mvr-address none
configure mvr vlan multicast static group none
configure mvr add vlan WIRELESS_MGMT
configure mvr vlan WIRELESS_MGMT mvr-address none
configure mvr vlan WIRELESS_MGMT static group none
# Module acl configuration.
configure access-list vlan-acl-precedence shared
(from Crosby_Tech)
Create Date: Oct 29 2013 5:04PM
Sorry for the delay,
try with firmware 15.3.1.4 v1531b4-patch1-14, 15.3.1.4 v1531b4 it's a bit old and have some bugs
Jarek
