N-Series Static LAG not working after Upgrading to 7.x Firmware
  • Article
  • Updated 5 years ago
  • (Edited)
Article ID: 13678
Products
Matrix N-Series DFE, firmware 7.11.01.0025 and higher
Changes
Configured a Static LAG ('set lacp static...').
Globally disabled LACP ('set lacp disable').
Symptoms
The Static LAG works fine with older firmware, until upgrading to 7.x firmware - even after following the special 'Transitioning to Firmware v7.0' instructions in 13533
Cause
In releases prior to 7.x, LACP is by default globally enabled ('set lacp enable'), a state which is required in order for Dynamic LAGs to function but optional in order for Static LAGs to function.
As of release 7.x, LACP is by default globally enabled ('set lacp enable'), a state which is required in order for Dynamic LAGs to function and also required in order for Static LAGs to function.
Configuration for both Dynamic and Static LAGs is explained in 5203
Solution
In order for any LAG to function with firmware 7.x or higher, ensure that the Global LACP state is returned to its default value:
'set lacp enable'.
See also: 12516.
Photo of FAQ User
FAQ User, Official Rep
  • 13,610 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
