NAC and end-system DB
  • Question
  • Updated 2 years ago
  • Answered
After a NetSight upgrade to 7.0.8.34 we don't see the End System list, but wireless clients auth is still working. The  netsight.tam_endsystem mysql tables contains only the previous upgrade records. Thank you for your help!
Photo of Michele dV
Michele dV
  • 110 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Mike Thomas
Mike Thomas, Employee - GTAC - NMS
  • 7,640 Points 5k badge 2x thumb
There are a few ways to interpret this.
What version where you running previously? Do the end station events appear for authenticated users in EMC or NAC Manager?
In 7.xx.xx End system event files have been moved into the central .sql database. There are no longer end system even files.
More info in below article.
https://gtacknowledge.extremenetworks.com/articles/Solution/NAC-End-System-event-logs-are-not-showin...
Photo of Michele dV
Michele dV
Thank you Mike, we upgraded from 7.0.3 to 7.0.8. In the NAC Manager the End-Systems tab (and the EndSytem Events tab) are empty.
Photo of Michele dV
Michele dV
Ok, I will open a case, thanks!
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,884 Points 20k badge 2x thumb
Hi, just to make sure... is there no filter set on the end-system view because that could also result in an empty view.
Please open the filter and select clear.
