NAC Appliance Web-Session timeout
  • 2
  • Question
  • Updated 2 years ago
  • Answered
is there a configuration option to change the default-timeout for the Web-session?
I'm connected to the Webserver of the NAC-Appliance (IP:8443/Admin), but the session is closing after ~5 minutes - very annoying.
Best Regards
Chacko
Photo of Chacko
Chacko
  • 1,206 Points 1k badge 2x thumb
Posted 2 years ago
  • 2
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,894 Points 20k badge 2x thumb
I don't think that you'd change it in the GUI, at least I can't find a way to do it.
Might be that someone from engineering could tell whether the parameter could be changed in some kind of config file on the NAC appliance.
-Ron
(Edited)
BTW, for what do you use the portal - I'm curious because I never use it and wonder whether I miss out on something :-)
Photo of James A
James A, Embassador
  • 6,962 Points 5k badge 2x thumb
I use the portal to turn debug logs on and off, particularly RADIUS and rule evaluation. There's some other interesting info in there, but nothing I'd use on a regular basis.
Photo of Chacko
Chacko
Yes, exactly the same over here (troubleshooting).
If you got the logs in the NAC-Appliance Web-GUI and want to compare them, e.g. with radius-logs of a different and with every refresh you have to login again, it's a little bit annoying.
Photo of SH
SH
  • 4,112 Points 4k badge 2x thumb
Hello Chacko,
it would be nice to change the session timeout! But maybe the following workaround can help you:
You can reach the NAC server.log via NAC Manager (the Java tool) with a right click on you appliance and selecting "NAC Appliance Log..."
Or you use a SSH session to your NAC Appliance and browse your logs (there are several) in /var/log/ and /usr/local/Extreme_Networks/NetSight/appdata/logs
