NAC - Guest Registration for Time-based Wireless Access (How-to)
  • Question
  • Updated 3 years ago
  • Doesn't Need an Answer
Hi Community,
I have a client that has Netsight, NAC and a C4110 Wireless controller.
The objective is as follows:
1. Create an SSID for guests
2. Guests should be presented with a Portal where they are required to create an account to have access
3. Access to this SSID is only to be available after hours (16:30 to 7:55)
From looking through the Hub, I can see that this is totally possible by using NAC, creating a rule and associating it with a time and an SSID.
I am just finding it a little hard to find a guide on how to exactly do this step by step.  The SSID is created, and it works, however the portal and NAC portion is still a little tricky.
I am sure that it is pretty simple, as the info that I have gone through seems to indicate this.
Does anyone have a guide that they can share ?
Thanks a mil !
Dewald
Photo of Dewald Botha
Dewald Botha
  • 674 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Andre Brits Kannemeyer
  • 5,020 Points 5k badge 2x thumb
Jis Dewald, Bel my dan help ek jou ;)
Photo of Drew C.
Drew C., Community Manager
  • 37,366 Points 20k badge 2x thumb
I'm going through older threads and wanted to ask if you still need assistance with this.
