NAC physical connectivity
  • Question
  • Updated 3 years ago
  • Answered
Hi all,
Is there a way to physically connect NAC IA-A-330-2 using LAG as it has 4 Ethernet ports?
Thanks in advance!
Husam
Photo of Husam
Husam
  • 1,272 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 10,226 Points 10k badge 2x thumb
Hi.
I do not believe it is supported, but there is linux ubuntu inside. You can try.
Z.
Photo of Tyler Marcotte
Tyler Marcotte, Official Rep
  • 2,818 Points 2k badge 2x thumb
Husam,
No, that is not a supported configuration. Also there is no real need for the LAG since the IA-A-300 is used in an out-of-band manner. You should never come anywhere near utilization that would would require more bandwidth than the standard gig port.
Tyler
Photo of Husam
Husam
Thanks for your answer. My purpose is to have redundant connection in case the port that NAC connected to failed. Is there any advice regarding this purpose.
Thanks
Husam
