NAC Portal: Pre-Registration expiration at first login
  • Question
  • Updated 1 year ago
  • Answered
i want using this new (netsight / NAC V7.x) feature. Unfortunately there is no documentation how i can use it ;-((
No online-help, no manual ...
If i create a new guest user i have to determine a exiration date - if i delete this field an error occurs.
i want creating a bunch of guest vouchers and they should expire after 5 days, starting from first login (and not from creation date)!
How can i do that ???
PS: i hate new feature that are not documentated!!!
Photo of M.Nees
M.Nees, Embassador
  • 8,736 Points 5k badge 2x thumb
Posted 1 year ago
Photo of SH
  • 1,720 Points 1k badge 2x thumb
Hello Matthias,
I have seen this feature working.
There is a help entry but I found it only in the online document. (
Please pay attention to the NOTE below. I think therefore your test goes wrong.
Pre-Registration Expiration at First Login
Select this checkbox to set the Default Expiration of a pre-registered user to begin when the user first registers a device, instead of setting it the moment the pre-registered user is created (added via the pre-registration administration process). Select Enable Pre-Registration Portal to enable this option. For more information, see How to Configure Pre-Registration.
This option is only valid when importing a CSV file to pre-register multiple users in the Pre-Registration Portal and not when entering information for a single user.
Photo of M.Nees
M.Nees, Embassador
Hi SH,
thanks for that advice.
I have to look for documentation of new features in OneView!
In JavaTool they have add the button but NOT the documentation !
Should be changed ...
Also that this simple but worthful feature is only available via CSV import and not via GUI creation of users (which is done be a secretary - CSV creation can only be done by the admin itself).
