NAC - speed up portal authentication
  • Question
  • Updated 3 years ago
  • Answered
Is there a way to speed up the NAC portal authentication.
So the guest get the portal page and select to accept the use policy but then it took a while to get the success - there is this loading animation.
Anyone know a trick to make it faster ?
Thx,
Ron
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,894 Points 20k badge 2x thumb
Posted 3 years ago
Photo of Mike Thomas
Mike Thomas, Employee - GTAC - NMS
  • 7,640 Points 5k badge 2x thumb
Hi Ron, Exactly how long is it taking?
I get the "registration in progress" animation for about 10-20 seconds.
I use a bridge@EWC topology and the roles are contain to VLAN - they client doesn't change the VLAN only different roles/ACLs for unregistered/guest access.
That is actually a very good speed.  During the transition to the policy or vlan that is assigned after the registration occurs, you must remember that there is a re-auth that takes place, and hence another IP Resolution process that also occurs, prior to NAC redirecting the page to whatever URL.  That is a good time;  some take upwards of 30 seconds.  Everyone’s networks is different and if they are changing vlans that can exacerbate the delay.
Photo of Curtis Parish
Curtis Parish
  • 3,332 Points 3k badge 2x thumb
We had a discussion with an extreme engineer last week about  some changes made in the latest NAC release  that can at least speed up the appearance of connecting.   If I remember correctly it involved skipping the accessing /registration redirect  page and instead having the  NAC agent throwing up a dialog box if the process failed.    As always there are trade offs and network designs vary greatly.  It  may be worth a look.
Photo of An-Tin Liu
An-Tin Liu
  • 478 Points 250 badge 2x thumb
mobile device like Iphone android OS,NAC portal is very slow.
iphone display portal page need 1-2 minute
android can't display portal page
how to slove it?
