NAC - VSP/ERS switch management using LDAP credentials
  • Question
  • Updated 4 months ago
  • Answered
I am trying to use NAC to allow switch management access (SSH/Telnet/Web) for an LDAP group.
Currently the VSP/ERS switches have been added to XMC NAC and I am able to backup configs, use scripts, etc. I am also able to assign VLANs to the ports via LDAP authentication.
Does anyone have instructions on how to configure NAC Policy to send the correct values to the VSP/ERS switches to allow management access?
Photo of Jay
Jay, Employee
  • 226 Points 100 badge 2x thumb
Posted 4 months ago
Photo of Yacobucci, Ryan
Yacobucci, Ryan, Multi-Tier Technical Support Engineer
  • 5,470 Points 5k badge 2x thumb
Hello James,
Give this article a shot:
https://gtacknowledge.extremenetworks.com/articles/How_To/allowing-mangement-access-to-Avaya-switche...
:edit: you'll need to create a rule with an LDAP user group criteria, but this article details the AVP that should work for management login :edit:
Thanks
-Ryan
(Edited)
Photo of Jay
Jay, Employee
  • 206 Points 100 badge 2x thumb
Ryan,
Thank you. This is what I was looking for.
Is there a way we can append an article to add the VSP/ERS RADIUS commands?
Hello James,
It can be appended, do you have a working configuration I can use to add content to the article?
Thanks
-Ryan
Photo of Jay
Jay, Employee
Yes, Below are the commands for VSP8284 v7.0.
enable
config terminal
radius server host <NAC IP> key <shared secret> used-by cli enable
(optional) radius reachability mode status-server
radius enable
Photo of ar
ar
  • 602 Points 500 badge 2x thumb
I guess the RADIUS server has to send back the RADIUS Attribute "Filter-ID" with the following information (for Enterasys switches):
Enterasys:version=1:mgmt=su:
Detailed information may be availabe if you search for "filter-id" in the knowledge base (i.e.:
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-filter-id-is-required-for-administrative...
Hope this will be helpful.
Regards,
Axel
