NAC with third Party wireless solution
  • Question
  • Updated 2 years ago
  • Answered
We are in the process of deploying a Extreme NAC solution with a third part wifi Solution (Fortinet Enterprise - Old Meru).
The solution requires us to return specific radius attributes.
When I add the "switch" as a NAC client I can select from the predefined radius attribute list or create a new one.
Some of the radius attributes refer to %custom% attributes.
For example the client wants to return the custom attribute only when a andriod device connects to the system and the attribute needs to be "name-vlanID" ie "staff-112"
Where on the rule do you specific the custom attribute to be returned?
Photo of Andre Brits Kannemeyer
  • 4,980 Points 4k badge 2x thumb
Posted 2 years ago
Photo of Yacobucci, Ryan
Yacobucci, Ryan, Multi-Tier Technical Support Engineer
  • 4,776 Points 4k badge 2x thumb
Hello Andre,
Check this article out:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-NAC-for-custom-radius-att...
The profile that is assigned to the rule has a policy mapping, inside this policy mapping you can use the Custom fields to put in attributes.
Thanks
-Ryan
Thx Ryan just what I needed.....
