Need direction in setting up mesh for AP7662 APs
  • 2
  • Question
  • Updated 5 months ago
  • Answered
Hi
I have 4 of the AP7662 units setup with an auto VC, but I cannot work out how to mesh these correctly. The case will be that 3 of the 4 will be root devices (LAN access) and the 4th will not have LAN access, but will need to mirror the wireless in an open dispatch yard.
I have tried following 9035201_WiNG_5_9_1_AP_SRG.pdf but I cannot find some of the options in my APs. Is there a step by step guide for setting this up?
Thanks,
Brett
Photo of Brett Morrison
Brett Morrison
  • 210 Points 100 badge 2x thumb
Posted 5 months ago
  • 2
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 5,116 Points 5k badge 2x thumb
Hello Brett,
you shall probably take a look to different guide.
Find MeshConnex Overview available from Documantation - Wireless & Mobility - Other Wireless Doc
You might have a SwiftUI loaded on your AP which looks pretty much different from the controller's graphical user interface. Try to use CLI instead or switch to EnterpriseUI
Let me know if you have further questions.
Regards,
Ondrej
Brett Morrison
Hi Ondrej
Thanks for the info - I am already on EnterpriseUI, but I have tried working through that mesh document and I have no options for meshconnex policy, so cannot create one. The only plac I can find anything on meshing is under System profile, the default profile, interface>radios, legacy mesh. This does not create a policy though.
All of my APs are 5.9.1.3-007R
Brett
Photo of Darrel Rhodes
Darrel Rhodes, Employee
  • 1,184 Points 1k badge 2x thumb
Hi Brett,
I understand that MESHConnex support won't be available on the 7662 AP platform until WiNG firmware version 5.9.2.
The release of this version is due in a month or two but unfortunately I don't have any firm release date to provide you with.
I hope this helps.
Best regards,
Darrel.
Brett Morrison
Thanks Darrel, at least I know now why the option is missing.
I'll review my installation plan and work around it.
thanks,
Brett
