Need to Configure Captive Portal in a Cluster of WM3600 locally, without External Radius
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
Need to Configure Captive Portal in a Cluster of WM3600 locally. I do not have external RADIUS.
How to configure Virtual Captive Portal Server Host/IP Address in a cluster of WM3600, for backup when primary controller fails ?
WM3600 in cluster of two Controllers with Version 5.4.
Presently basic SSID is working. Need to enable Captive Portal on same SSID.
Regards,
Jitendra
Photo of Jitendra Patel
Jitendra Patel
  • 402 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Hi Jitendra,
I would suggest opening up a case with GTAC for this. This can get fairly complicated (especially the redundancy part), so this will ensure that we are able to get this the attention that is needed.
When you open up the case, please include a tech-support from the wireless controller, and be sure to specify the name of the WLAN that you want to configure this on.
-Brandon
PS: This is still open to the community as well, so if any one else has any input, feel free to chime in.
Jitendra Patel
Hi Brandon,
Thanks for your suggestion.
Regards,
Jitendra
