Need help : Port 80 is not closed.
  • Question
  • Updated 4 years ago
Create Date: Mar 13 2013 3:06AM
Hi everyone, I have a Extreme Summit x450A..
I was trying to disable the http web access to the switch since I am using https to access to the switch.
However, after I issued "disable web http" command, save configuration and restarted the switch. I am still able to access to the login page through http://switch_ip
Just that it prompts http request error when I try to login and view the detail.
My question is.. how to totally closing port 80 down because I dont even wan the web login page accessible.
Thanks
(from hengchuen)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Mar 13 2013 8:11PM
Very strange - what version of XOS are you running? It could be a bug, or there could be something else at work. At any rate you could make an ACL that blocks port 80 on the interface:
entry block-80 {
if {
destination-address swi.tch.i.p/32 ;
destination-port 80 ;
} then {
deny;
(from Ansley_Barnes)
Create Date: Mar 13 2013 8:46PM
Very Strange can you do a show man after you disable it to verify that it is off?  Before you restart it try and access it via web to make sure it is down.
Thanks
P
(from Paul_Russo)
Create Date: Mar 14 2013 8:06AM
May be you must upgrade that switch firmware, because i use 15.x always ok (deny access) but version 12.6 will fail (web can be access)
(from Hsu_LiPing)
