Netisght flex view historical
Luis_Mendes
Contributor
Hi, i would use netsight to monitor others vendors and informations about this, the netsight only monitor troughput historical.
Its possible create a flex view and create reports using this flex view with data historical???
or flex view is only to view a read of actual state??
5 REPLIES 5
Bharathiraja__S
Hi Luis,
What is the device , Switch , router or server?
are you looking for an option like syslog ?
Thanks,
Suresh.B
This device is a outdoor radio.. device not send this information with syslog, but the information is read by snmp
Bharathiraja__S
Hi Luis,
Please check below article, are you looking for this report?
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-Find-Port-Utilization-Statistics-Us...
Thanks,
Suresh.B
Bharathiraja__S
Hi Luis,
Please explain your requirement in detail, what are you trying to achive? Do you have any sample report or format?
Thanks,
Suresh.B
