netlogin mac authentication issue
  • Problem
  • Updated 12 months ago
  • Solved
Correct me if i am wrong:
In NetLogin by mac address, the user and password sent by the Summit to the NPS are capitalized(uppercase) . As the case sensitice password, how can I make the switch to send the password in lowercase?
Best Regards
VB
Photo of Vitor Barreiro
Vitor Barreiro
  • 272 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,514 Points 5k badge 2x thumb
Hi Vitor,
Current implementation does not have an option to change the case of "user-password" attribute to lower case so this case be further submitted as a feature request to check if this can be implemented in the future
Vitor Barreiro
Ok. In the meanwhile is it possible to run a script in the switch to change the password to lower case?
Hi Vitor,
I believe you can chance the password to upper case in Active Directly, i would say that is an easy option.
since the packet is generated by the CPU I am not sure if a script can do it, i would say it has to be a change in the code...Still i would check with the team if this is possible via a script.
Hi Vitor,
Unfortunately it is not possible via script.
Photo of M.Nees
M.Nees, Embassador
  • 9,156 Points 5k badge 2x thumb
same problem at my current project - several thousands mac addresses are part of global NPS in lower case because this is HP switching default. EXOS now only support upper case ...
HP / Brocade / Cisco support to define the format of mac authentication (upper / lower case ....)
This is a overdue feature!
Is there maybe a way to transform the mac format if it goes through Extreme NAC Gatway ?
Is there maybe a way in NPS to ignore password checking (because i think, only password checking in NPS is case sensitive, not username) ?
Regards
