NETLOGIN MAC BASE
  • Question
  • Updated 4 years ago
Create Date: Mar 5 2013 9:02AM
HELLO,
can some one help me about NETLOGIN MAC BASE authentication  configuration and sceanrio. i want to authenticate my 10 host laptop mac address
in local radius as extreme switch.please share configuration and and how host are authenticated.
i have tried with below config.
here is my config:
configure netlogin vlan nlvlan
enable netlogin mac
enable netlogin ports 4 mac
configure netlogin ports 4 mode port-based-vlans
configure netlogin ports 4 no-restart
configure netlogin add mac-list 88:ae:1d:2a:8b:32 48 ports 4
(from keshab_maharjan)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Mar 5 2013 2:22PM
Have you created a MAC entry in the local database?
you can do it by running the commmand:
create netlogin local-user "88AE1D28B32" ## hit enter, it will prompt you for a password. Put the same MAC address again as a password.
Let us know how it goes from there.
(from ethernet)
Create Date: Mar 6 2013 6:12AM
Thanks for reply.
i have configured netlogin user like you said.
but when i checked
* X250e-24tdc.16 # sh netlogin port 4
Port                          : 4
Port Restart                  : Disabled
Allow Egress                  : None
Vlan                          : nlvlan
Authentication                : mac-based
Port State                    : Enabled
Guest Vlan                    : Disabled
Auth Failure Vlan             : Disabled
Auth Service-Unavailable Vlan : Disabled
MAC                IP address       Authenticated     Type    ReAuth-Timer   User
88:ae:1d:2a:8b:32  0.0.0.0          No                MAC     0
(B) - Client entry Blackholed in FDB
could you please guide me regarding how mac address are authenticated.
Thanks
Create Date: Mar 6 2013 5:56PM
Try to force the switch to take the local database for MAC addresses by running the command:
configure netlogin mac authentication database-order local
Let us know if this works.
(from ethernet)
Create Date: Mar 7 2013 5:48AM
please get my full config..
configure netlogin vlan vlan_10
enable netlogin mac
X250e-24tdc.19 # sh netlogin port 4
Port                          : 4
Allow Egress                  : None
Vlan                          : vlan_10
          MAC Mode Global Configuration
MAC Address/Mask      Password (encrypted)            Port(s)
88:AE:1D:2A:8B:32/48  <not configured>                4
Re-authentication period    : 0 (Re-authentication disabled)
Authentication Database        : Local-User database
Port: 4,  Vlan: vlan_10,  State: Enabled,  Authentication: mac-based
Guest Vlan <Not Configured>: Disabled
Authentication Failure Vlan <Not Configured>: Disabled
Authentication Service-Unavailable Vlan <Not Configured>: Disabled
################################3
still no authentication please guide how can i verify....
Create Date: Mar 7 2013 2:52PM
I actually ran into an issue with case-sensitivity before. Remove the command:
configure netlogin add mac-list 88:AE:1D:2A:8B:32 48 ports 4
Also, the username and password in the create netlogin local-user command, make sure those are uppercase too.
Hopefully, that is what is the last command that is missing from the switch.
(from ethernet)
Create Date: Mar 11 2013 5:06AM
same thing... after configuring with upper case
configure netlogin add mac-list 88:AE:1D:2A:8B:32 48 ports 4 and netlogin local-user..
* X250e-24tdc.40 # sh netlogin port 4
Port                          : 4
Allow Egress                  : None
Vlan                          : vlan_10
could you please guide me how users authenticated..where we put user name and password which was created in SWITCH... do i need to dial..
Create Date: Mar 11 2013 5:13PM
Try to open the netlogin configuration to all MACs by running the command:
Configure netlogin add mac-list FF:FF:FF:FF:FF:FF 48 port X
This will *NOT* allow all devices to be authenticated. Only devices created in the Local DB by running the command "create netlogin local-user ...."
(from ethernet)
Create Date: Mar 14 2013 5:12AM
hello,
pls get my full config
configure netlogin vlan vlan_101
enable netlogin mac
enable netlogin ports 24 mac
configure netlogin ports 24 mode port-based-vlans
configure netlogin ports 24 no-restart
configure netlogin add mac-list 88:ae:1d:2a:8b:32 48 ports 24
configure netlogin add mac-list ff:ff:ff:ff:ff:ff 48 ports 24
* X250e-24tdc.23 # sh netlogin local-users detail
NetLogin Local User information:
User Name         : 88AE1D2A8B32
Extended-VLAN VSA : <not configured>
Security Profile  : <not configured>
Encrypted Password: 5v8oYJ$0jqA68g/xERMtonL0Wgq6.
X250e-24tdc.25 # sh netlogin mac
NetLogin Authentication Mode : web-based DISABLED;  802.1x DISABLED;  mac-based ENABLED
NetLogin VLAN                : "vlan_101"
NetLogin move-fail-action    : Deny
NetLogin Client Aging Time   : 5 minutes
Dynamic VLAN Creation        : Disabled
Dynamic VLAN Uplink Ports    : None
88:AE:1D:2A:8B:32/48  <not configured>                24
Default               <not configured>                24
Port: 24,  Vlan: vlan_101,  State: Enabled,  Authentication: mac-based
* X250e-24tdc.26 # sh fdb ports 24
Mac                     Vlan       Age  Flags         Port / Virtual Port List
Flags : d - Dynamic, s - Static, p - Permanent, n - NetLogin, m - MAC, i - IP,
        x - IPX, l - lockdown MAC, L - lockdown-timeout MAC, M- Mirror, B - Egress Blackhole,
        b - Ingress Blackhole, v - MAC-Based VLAN, P - Private VLAN, T - VLAN translation,
        D - drop packet, h - Hardware Aging, o - IEEE 802.1ah Backbone MAC,
        S - Software Controlled Deletion
Total: 2 Static: 0  Perm: 0  Dyn: 2  Dropped: 0  Locked: 0  Locked with Timeout: 0
FDB Aging time: 300
* X250e-24tdc.30 # sh netlogin port 24
Port                          : 24
Allow Egress                  : None
Vlan                          : vlan_101
please help how  netlogin works with local database and authenticated....
