netlogin still on port
  • Question
  • Updated 4 years ago
We are running Extreme switches in multiple buildings. We have netlogin dot1x and mac on all the ports. They all authenticate pretty good. Our first building we did as a POC. When a phone is plugged in it authenticates fine and when the computer plugged into it powers on it authenticates as well. Both locations use the vlan netloginTemp as the netlogin vlan. The one thing that I see that I'm questioning is how the ports look once the phone and computer are both up and going.
Below are two partial outputs from two seperate devices. You can see that each port has the Phone and Data vlan (for the voip and computer), however the bottom copy shows that the netloginTemp vlan is still on the port. What would cause this to happen? Any ideas or recommendation of commands to run to try and figure this out? Thanks!
Port: 1:21
Virtual-router: VR-Default
Type: UTP
Random Early drop: Unsupported
Admin state: Enabled with auto-speed sensing auto-duplex
Link State: Active, 1Gbps, full-duplex
Link Ups: 3 Last: Tue Nov 26 09:19:00 2013
Link Downs: 2 Last: Tue Nov 26 09:09:44 2013
VLAN cfg:
Name: Phone, 802.1Q Tag = 61, MAC-limit = No-limit, Virtual router: VR-Default
Name: Data, Internal Tag = 60, MAC-limit = No-limit, Virtual router: VR-Default
Port: 15
Type: UTP
Link Ups: 6 Last: Thu Apr 10 13:49:09 2014
Link Downs: 5 Last: Thu Apr 10 13:49:07 2014
VLAN cfg:
Name: Data, Internal Tag = 60(MAC-Based), MAC-limit = No-limit, Virtual router: VR-Default
Name: Phone, 802.1Q Tag = 61(MAC-Based), MAC-limit = No-limit, Virtual router: VR-Default
Name: netloginTemp, Internal Tag = 4094(MAC-Based), MAC-limit = No-limit, Virtual router: VR-Default
Photo of bw447
bw447
  • 906 Points 500 badge 2x thumb
Posted 4 years ago
Be the first to post a reply!
