NetSight 6.1.171 with Extreme Summit switch X430 firmware 15.6 always snmp timeout?
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
Our customer use NetSight 6.1.171 with Extreme Summit switch X430 firmware 15.3, and NetSight sometimes shows snmp timeout error.
I ask the problem on HUB, and got it will resolve with NetSight 6.2 and XOS 15.4 or later.
Since the NetSight 6.2  does not release, I upgrade the XOS to 15.6 first.
After upgrade XOS to 15.6, it "always" got snmp timeout error,
and sometimes causes the switch SNMP Contact Lost:contact on NetSight.
Will the problem be resolved on NetSight 6.2?
This is driving me crazy...
Photo of Shunze Lee
Shunze Lee
  • 732 Points 500 badge 2x thumb
  • crazy
Posted 3 years ago
Photo of Shunze Lee
Shunze Lee
After download the NetSight 6.2.0.183, the snmp timeout problem does not reslove.
I found it was caused by search some Enterasys MIB on Extreme Summit Switch.
Uncheck the Enterasys MIB option, the compass search function works great with out any error finally.
Photo of Drew C.
Drew C., Community Manager
  • 37,336 Points 20k badge 2x thumb
Hi Shunze,
Thanks for sharing your solution with us!
It sounds like this could be a bug - Netsight shouldn't use an Enterasys MIB on devices that don't speak that language.  Would you mind opening a case with GTAC to report this (and your workaround)?
Photo of Martin Flammia
Martin Flammia
  • 5,724 Points 5k badge 2x thumb
Great Solution!!! This had been driving me crazy for ages too. Getting exactly the same results and this fixed my problem.
I have a case open on 01110668.
Have a switch that currently works on the network and one taken out of the box and upgraded firmware that doesn't. Output shown below:
Netsight 6.2.0.199
Clinet JRE: 1.7.0_60 32bit
X460-48x Firmware 15.3.1.4 Boot ROM 2.0.1.0
08:08:51 08/04/2015       INFO                             All search on My Network (xxx devices, 9 ports)->Grouped By (xxx devices)->Device Type (xxx devices)->Summit Series (xx devices)->X460 (xx devices)->X460-48x (x devices)->xxxxx_X460 started
08:08:51 08/04/2015       INFO                             Search filter: [NONE SPECIFIED]
08:08:51 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading NAC EndSystem table
08:08:51 08/04/2015       INFO     xxx.xxx.xxx.xxx            1          Reading sysUpTime
08:08:51 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Skipping vtpVlanTable
08:08:51 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading extremeLocationDetectMethods
08:08:55 08/04/2015       INFO     xxx.xxx.xxx.xxx            284       Reading dot1dTpFdbTable
08:08:55 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading dot1qVlanCurrentTable
08:08:55 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading dot1qTpFdbTable
08:08:55 08/04/2015       INFO     xxx.xxx.xxx.xxx            2          Reading dot1dBasePortTable
08:08:55 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Checking ctAlias table support
08:08:55 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading ctAliasTable
08:08:55 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading ctIGMPCacheTable
08:08:55 08/04/2015       INFO     xxx.xxx.xxx.xxx            6          Reading igmpCacheTable
08:08:55 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading ipNetToPhysicalTable
08:08:55 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading ipv6NetToMedia
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx            129       Reading ipNetToMediaTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading dot1xAuthSessionStatsTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading dot1xAuthStationTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading etsysMulti1xSessionStatsTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading etsysDot1xAuthSessionStatsTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading etsysPwaAuthSessionStatsTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading hostControlTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading addressMap
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading etsysMACAuthenticationSessionTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading etsysMultiAuthSessionStationTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading etsysConvEndPointConnMacTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading etsysMACLockingStationTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading ctIfTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx            4          Reading ifTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx            4          Reading ifXTable
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading ctCDPNeighbor
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading dot3adAggPortListPorts
08:08:58 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Finished querying device.
08:09:00 08/04/2015       INFO                             All search on My Network (xxx devices, 9 ports)->Grouped By (xxx devices)->Device Type (xxx devices)->Summit Series (xx devices)->X460 (xx devices)->X460-48x (x devices)->xxxxx_X460 finished successfully
X460-48t Firmware 15.6.2.12 Boot ROM 2.0.1.7
08:15:07 08/04/2015       INFO                             All search on My Network (xxx devices, 9 ports)->X460-48t started
08:15:07 08/04/2015       INFO                             Search filter: [NONE SPECIFIED]
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading NAC EndSystem table
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx            1          Reading sysUpTime
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Skipping vtpVlanTable
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading extremeLocationDetectMethods
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx            9          Reading dot1dTpFdbTable
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading dot1qVlanCurrentTable
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading dot1qTpFdbTable
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx            1          Reading dot1dBasePortTable
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Checking ctAlias table support
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading ctAliasTable
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading ctIGMPCacheTable
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx            5          Reading igmpCacheTable
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading ipNetToPhysicalTable
08:15:07 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading ipv6NetToMedia
08:15:08 08/04/2015       INFO     xxx.xxx.xxx.xxx            3          Reading ipNetToMediaTable
08:15:08 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading dot1xAuthSessionStatsTable
08:15:08 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading dot1xAuthStationTable
08:15:09 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading etsysMulti1xSessionStatsTable
08:15:17 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Reading etsysDot1xAuthSessionStatsTable
08:15:29 08/04/2015       ERROR xxx.xxx.xxx.xxx                        Unable to contact device. ERROR: SNMP Timeout
08:15:29 08/04/2015       INFO     xxx.xxx.xxx.xxx                        Finished querying device.
08:15:29 08/04/2015       INFO                             All search on My Network (xxx devices, 9 ports)->X460-48t finished with errors
(Edited)
Photo of Shunze Lee
Shunze Lee
It's my pleasure to help you.
