Netsight 6.3 to Extreme Management 7.0
  • Question
  • Updated 2 years ago
  • Answered
Would it be best to build a new server for the 7.0 or upgrade the existing 6.3 server? Has anyone installed this new version yet and what are your thoughts?
Photo of DH
DH
  • 1,024 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,286 Points 20k badge 2x thumb
I don't see a problem to upgrade - I've done it now with 2 systems and installed another one from scratch and it works great.
Photo of David Choi
David Choi, Employee
  • 1,966 Points 1k badge 2x thumb
Please note that the only way to downgrade from 7.0 back to 6.3 is re-installation of 6.3 version. So if you have a room, it would be better to install the new version on another server and test before upgrading the existing 6.3 server. I had an issue for drawing map using LLDP on OneView and it was fixed in the latest version of 6.3.0.182 and 7.0.2.33.
Photo of Rahman Duran
Rahman Duran
  • 2,012 Points 2k badge 2x thumb
Photo of Chris Sorge
Chris Sorge
  • 80 Points 75 badge 2x thumb
Did you ever find a solution to this error?  I receive the same after a recent upgrade.  I have done a fresh install, and it works properly.  Something must have went amiss during the upgrade process.
Photo of DH
DH
It looks like I will go ahead and do the upgrade today since I was told it should fix some issues I am currently having. I am sad to find out that it still doesn't have the SSH/Telnet option from the right click on the device. I am sure I will find out when I do the upgrade and go through the documentation but is the Console gone in this version and everything done through the web view?
You could still use the "old" legacy console Java app.
You'd start it right from the Extreme Management Center...
Photo of DH
DH
Great, thanks for the info!
Photo of Christoph
Christoph
  • 1,812 Points 1k badge 2x thumb
I had upgraded 2 smaller installations with just a few switches and a little policy environment. I had no issues, it works as aspected.
I will use these environments as a real life evaluation before upgrading customers with several hundred switches.
The new Web GUI centralized approach is quite cool, but it's different to work with it.
There are still some functionalities which are available through the legacy consoles, only. E.g. VLAN Manager.
