Netsight alarm self clear
  • Question
  • Updated 3 years ago
  • Answered
Is there a way to have alarms auto clear if the event causing the alarms clear.
Photo of Justsomebodi
Justsomebodi
  • 1,572 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Curtis Parish
Curtis Parish
  • 3,332 Points 3k badge 2x thumb
In alarm details, third tab (other options) there is a check box for "cleared by alarms."  You have to create an "alarm" that clears the first one.    So if your alarm is for interface down you create another alarm for interface up and put that one in the "cleared by" option of the interface down alarm.
Justsomebodi
Great, but what does one do with something like a Loop alarm which doesn't send a loop gone trap?
Curtis Parish
Is the loop alarm a trap?
Justsomebodi
Hi
Yes and know. We do have a trap, but we use the syslog for the alarm.
Curtis Parish
 I would suggest looking at  syslog severity levels and see if there are any messages at the info level that say the loop condition is gone.
