netsight_appliance_64bit.6.3.0.168.ova not work access to the Web console after installation .
  • Question
  • Updated 3 years ago
  • Answered
I've done seven facilities in 3 different vmware appliance servers but can not open the web session and reviewing the list of ports are not available on 8080 and 8083 , 8084 .
when running on the server the command netstat -an | grep -i LISTEN sample having only few ports open , you can see the image.
Photo of Jairo Rojas Herrera
Jairo Rojas Herrera
  • 1,452 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Joseph Burnsworth
Joseph Burnsworth
  • 2,328 Points 2k badge 2x thumb
I had posted the wrong info for you. Im sorry for that. I do believe I have an answer for that one too. Ill be right back with that
(Edited)
Joseph Burnsworth
Here you go, try this.
sudo iptables -A INPUT -p tcp --dport 8080 -j ACCEPT
sudo iptables -A INPUT -p tcp --dport 8443 -j ACCEPT
Let me know if this helps.
(Edited)
Joseph Burnsworth
youll have to remove the break symbols out. I dont know why it keeps adding them
Photo of Drew C.
Drew C., Community Manager
  • 37,366 Points 20k badge 2x thumb
Welcome to The Hub!
Formatting with code and pre tags can be weird here.  I went ahead and fixed that post for you :)
(Edited)
Joseph Burnsworth
Thank you
Jairo Rojas Herrera
I'll try and tell you
Thks
Jairo Rojas Herrera
don ́t work with this command.
Joseph Burnsworth
The command didn't work or the command didn't fix it?
I was able ro replicate the issue and it resolved it
Jairo Rojas Herrera
the command was not run
Joseph Burnsworth
ok, try this one.
/usr/postinstall/dnetconfig
This will take you through the network config again. Accept the defaults shown (It is what is already configured) and then restart with this line
shutdown -r now
try this and let me know
Joseph Burnsworth
Did you happen to get this working?
