Netsight ELRP script
  • Problem
  • Updated 3 years ago
  • Solved
Hi All
I need to change the settings of ELRP interval. I have found this script which i am sure can be used in Netsight.
disable clipaging
enable elrp-client
set var sv "#ELRP POLL STARTED#"
show var sv
set var cli.out 0
show vlan
set var sv $TCL(split ${cli.out} "\n")
set var e $TCL(lsearch $sv *(B)*)
set var i 5
set var e ($e - 1)
while ($i < $e) do
   set var cli.out 0
   set var v $TCL(lindex $sv $i)
   set var vn $TCL(lindex $v 0)
   set var z $TCL(regexp {Mgmt} $vn)
   if ($z == 0) then
         conf elrp-client one-shot $vn port all print
         set var p $TCL(split ${cli.out} "\n")
         set var p1 $TCL(lsearch $p *NO*)
         if ($p1 == -1) then
            set var p1 $TCL(lindex $p 2)
            set var p2 $TCL(lindex $p1 9)
            set var p1 $TCL(lrange $p1 0 6)
            set var p1 $TCL(concat $p1 $p2)
            set var p2 $TCL(lindex $p 3)
            set var p2 $TCL(lrange $p2 5 7)
            set var p $TCL(concat $p1 $p2)
            show var p
         else
            set var p2 $TCL(lindex $p1 10)
            set var p1 $TCL(lrange $p1 0 7)
            show var p1
         endif
   endif
   set var i ($i + 1)
endwhile
disable elrp-client
enable clipaging
set var sv "#ELRP POLL COMPLETED#"
show var sv
But am unsure as to how much of it i need. All I need to do is conf elrp-client periodic vlan ($variable) ports all interval 20
The above sript does way more, so i assume i can delete parts of it. Does anyone know which ones?
Also would i need to add excluded ports to the script even though it has already been defined.
Photo of Justsomebodi
Justsomebodi
  • 1,572 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Matthew Helm
Matthew Helm, Employee
  • 1,852 Points 1k badge 2x thumb
Changing the interval is a bit more complicated. If you were to try to change the interval of an existing elrp-client configuration, you would get a error message like: "ERROR: An active session already exists for "CLI:Default" !"
I can write a script that checks current configuration of elrp and changes the interval, if you'd like.
#This script updates the interval on eljrp-client sessions
# set the variable below
#This only works on EXOS 16.1 forward
set var int 3
disable clip
show elrp
set var CLI.OUT 0
show elrp
set var s $TCL(split ${CLI.OUT} "\n")
set var i $TCL(lsearch $s *----*)
set var i ($i + 1)
set var e $TCL(lsearch $s *Print\,*)
set var e ($e - 1)
while ($i < $e) do
   set var l $TCL(lindex $s $i)
   set var v $TCL(lindex $l 1)
   set var p $TCL(lindex $l 2)
   set var n $TCL(lindex $l 3)
   set var a $TCL(lindex $l 8)
   set var d $TCL(lindex $l 9)
   set var t $TCL(regexp {\-} $d)
   set var t1 $TCL(regexp {L} $a)
   set var t2 $TCL(regexp {T} $a)
   set var t3 $TCL(regexp {E} $a)
   set var t4 $TCL(regexp {I} $a)
   set var t5 $TCL(expr $t1 && $t2)
   set var lt "log"
   set var ie ''
   if ($t2) then
      set var lt "trap"
   endif
   if ($t5) then
      set var lt "log-and-trap"
   endif
   if ($t3) then
      set var ie "egress"
   endif
   if ($t4) then
      set var ie "ingress"
   endif
   set var recmd $TCL(concat "config elrp-client periodic" $v "ports" $p "interval" $int $lt)
   if (!$t) then
      set var recmd $TCL(concat $recmd "disable-port" $ie)
      set var t $TCL(regexp {\d+} $d)
      if ($t) then
         set var d $TCL(concat "duration" $d)
      endif
      set var recmd $TCL(concat $recmd $d)
   endif
   unconfig elrp $v
   $recmd
   set var i ($i + 1)
endwhile
Justsomebodi
Thanks for that, so i assume then the ELRP would need to be removed and then re-enabled with the different interval on each Vlan. As i am no scripting guru i assume that's what the script does.
(Edited)
Yes. It takes the int variable in at the top and makes that the interval for all ELRP VLAN instances. It assumes you are not running any one-shot instances of ELRP on a VLAN. It only works on 16.1 forward because the ports are shown in the output without spaces in that release of EXOS fwd, else it could get really messed up.
Justsomebodi
Thanks for the explanation.
(Edited)
Justsomebodi
Hi
Tested the script and it failed with the below error
*** Error at line - 59 ***
invalid command name "config elrp-client periodic <VLAN ID> ports All interval 5 log disable-port ingress 300"
Line 59 is
I am so confused. Doesn't seem to like the ingress 300 bit.
if (!$t) then
      if ($t) then
So i did
   if (!$t) then
      set var recmd $TCL(concat $recmd "disable-port" $ie "duration")
      if ($t) then
      endif
   endif
But still get the error.
invalid command name "config elrp-client periodic Extreme1 ports All interval 3 log disable-port ingress duration 300"
The command works in the cli.
(Edited)
What version of EXOS are you running?
Justsomebodi
XOS 16.1.1.4
Can you also send me the output of a "show vlan" command. Perhaps there is something in the vlan name triggering. Also a "show elrp". (It might be good to issue the "disable clip" command before doing these commands). I'll try to configure my switch to match yours as closely as possible and test it.
BTW, here is the ELRP configuration against which I tested the script:
# sho elrp
ELRP Standalone Client:       Enabled
Number of ELRP sessions:          4
Number of ELRP pkts transmitted:  397
Number of ELRP pkts received:     0
                                                       Pkts    Pkts        Disable
Client  VLAN        Ports   Interval Count Cyclic      Xmit    Rcvd Action Port (sec)
CLI     Default     1-2,4          3     0 Yes            3       0 LTI    Perm
CLI     VLAN_0101   All            3     0 Yes            1       0 LE     20
CLI     VLAN_0102   All            3     0 Yes            1       0 T      -
CLI     VLAN_0103   All            3     0 Yes            1       0 L      -
Action : (P) Print, (L) Log, (T) Trap, (C) Callback, (E) Egress, (I) Ingress
No errors detected.
Running 16.1.3,6-patch1-2
Justsomebodi
I see you aren't using 16.1.1.4. Is it possibly a issue with 16.1.1.4?
Just tested on 16.1.1.4 and no errors either.
Justsomebodi
show Vlan
Default         1    ------------------------------------------------- ANY    0 /0   VR-Default
Extreme1        25   ------------------------------------------------- ANY    0 /0   VR-Default
BB-MGMT       30   10.100.30.199   /24  -f--------------------------- ANY    1 /1   VR-Default
Mgmt            4095 ------------------------------------------------- ANY    0 /1   VR-Mgmt
Show ELRP
CLI     Extreme1    All            3     0 Yes            0       0 LI     300
The script ends up removing all Vlan's. I am using this from Netsight as a admin script.
(Edited)
I assume you mean the script ended up removing ELRP from all VLANs. I've been testing it from the CLI. I'll test it from NS when I have a chance.
Justsomebodi
Yes, sorry mean elrp from the vlan's. I am running the script from Oneview so is not actually Netsight (6.3.0.168)
I modified it to work in as a OneView script:
#@MetaDataStart#############################################################################################
# Define your user parameters in this section. For reference, see bundled scripts.
# @VariableFieldLabel (description = "Interval (number > 0)")
set var int 1
#@MetaDataEnd
# Enter all CLI commands from here
disable clip
set var CLI.OUT 0
show elrp
set var i ($i + 1)
set var e ($e - 1)
while ($i < $e) do
   set var lt "log"
   set var ie ''
   if ($t2) then
      set var lt "trap"
   endif
   if ($t5) then
   endif
   if ($t3) then
      set var ie "egress"
   endif
   if ($t4) then
   endif
   unconfig elrp $v
   if (!$t) then
         if ($t) then
            configure elrp-client periodic $v ports $p interval $int $lt disable-port $ie duration $d
         else
            configure elrp-client periodic $v ports $p interval $int $lt disable-port $ie perm
         endif
   else
   endif
   set var i ($i + 1)
endwhile
Justsomebodi
Thanks, i will give it a test.
