Netsight installation failed: Installer exiting with code: 130
Otto_Rosales
2016-09-22 16:00:53,810 INFO [com.enterasys.util.services.ServiceUtils] Unable to get JBoss status: Connection refused
2016-09-22 16:00:55,792 INFO [com.enterasys.netsight.install.ui.panels.BasePanel] Waiting for: Installation Complete - Database has started and Server is Not Started
2016-09-22 16:00:55,811 INFO [com.enterasys.util.services.ServiceUtils] Unable to get JBoss status: Connection refused
2016-09-22 16:00:57,812 INFO [com.enterasys.util.services.ServiceUtils] Unable to get JBoss status: Connection refused
2016-09-22 16:00:59,813 INFO [com.enterasys.util.services.ServiceUtils] Unable to get JBoss status: Connection refused
2016-09-22 16:01:01,813 INFO [com.enterasys.util.services.ServiceUtils] Unable to get JBoss status: Connection refused
3 REPLIES 3
Otto_Rosales
I am performing a new installation. Seslinux is disabled and iptables is also disabled. I am installing the software on a redhat 6.5 Santiago. Thank you in advance for your reply.
Zdeněk_Pala
Can be also antivirus installed or some firewall. Not sure what is the operating system you install it on. Are you doing upgrade or installing new?
Regards Zdeněk Pala
Ronald_Dvorak
Honored Contributor
