netSight map uplink is not showing
  • Problem
  • Updated 3 years ago
  • Solved
Photo of Mohammed Jasheer
Mohammed Jasheer
  • 916 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
What version of Netsight and do you have EDP or LLDP turned on?
Mohammed Jasheer
Hai BILL
                    we are using 6.2 am enabled lldp.
What specific version?  The latest is 6.2.0.221 - There was a specific issue with maps in earlier versions of 6.2.  I believe from .199 it was fixed.
Mohammed Jasheer
am using 6.2.0.199
Just to check connectivity if you do a "show lldp neighbor" do you see all of the adjacent switches? Are these switches EOS or XOS based?
Photo of Drew C.
Drew C., Community Manager
  • 40,694 Points 20k badge 2x thumb
Hi Mohammed,
Did Bill's suggestions and questions help you to find an answer to this issue?
