Netsight Maps for Multi-Floor Buildings
  • 3
  • Question
  • Updated 2 years ago
  • Answered
It does not appear to me that the Netsight Building Maps feature has any ability to account for multi-floor buildings in showing coverage heatmaps, etc. (as Ekahau does).  IE, it does not appear that you can specify when creating a floor plan, that there is a floor above or below it, and display the RF coverage that will bleed through the floor.
1. Has anyone found a work-around to this? Such as, if you import a Ekahau site survey file with multiple floors mapped, does Netsight show the signal from the other floors?
2. Are there any plans to configure a map/building to contain multiple floors?
Thanks!
Photo of Schmotter, Ryan
Schmotter, Ryan, Employee
  • 590 Points 500 badge 2x thumb
Posted 3 years ago
  • 3
Photo of Bob Maheu
Bob Maheu, Employee
  • 1,040 Points 1k badge 2x thumb
Hello Ryan,
I'm currently checking with Engineering on this one, but I do not see that we take this into account.
Photo of Bob Maheu
Bob Maheu, Employee
Hello Ryan,
1.  When importing the Ekahau files  it will import only the floor not the signal – signal is calculated by the NetSight.
2.  NetSight calculates only for one floor.
