Netsight Palo-Alto integration guide
  • Question
  • Updated 12 months ago
  • Answered
Does anyone know what happened to the guide?
Photo of Justsomebodi
Justsomebodi
  • 1,572 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Mike Thomas
Mike Thomas, Employee - GTAC - NMS
  • 7,498 Points 5k badge 2x thumb
It is still around.
If you look under partner resources below.
https://extranet.extremenetworks.com/downloads/Pages/OneFabricConnect.aspx
Photo of Luis Mendes
Luis Mendes
  • 1,668 Points 1k badge 2x thumb
How i download ONEFABRIC CONNECT ?
Photo of Daniel Flouret
Daniel Flouret, Employee
  • 7,470 Points 5k badge 2x thumb
The API is included in Extreme Management Center v7.0.
For previous releases, you must download and install a plugin that is kind of hidden. You can find it in the Extranet under SDK Connect:
There, under the Partner Resources tab you will find several different versions of the plugin. Which one to use depends on the release of NetSight (now known as Extreme Management Center)
Is there any documentation for Palo Alto plugin built in Extreme Management Center v7.0? Fields there, are different then in documentation for previous version in this link: https://extranet.extremenetworks.com/downloads/Pages/dms.ashx?download=a399e9c2-5f8f-4333-a70e-b9302...
Krzysztof,
If you have 8.0 installed, the info is in the Contextual Help, in https://<EMC_IP_address>:8443/Clients/help/content/oneview/docs/connect/docs/ov_connect_security.htm#Palo
Here's a document detailing the same info for Extreme Connect v3: https://app.box.com/s/ritf9yfb5ldd39wztx1tzevy4007159w
Hope this helps.
Thank you Daniel, I'm sure it will help! I was looking for this document for quite a long time.
Justsomebodi
Excellent thanks
