Netsight V8 - WebShell - logging functionality
M_Nees
Contributor III
Currently i do some lab test to get in contact with the new Netsight V8.
Now SSH is directly useable within OneView (Web Browser). It works nice and very fast.
But i am looking for way to grep all the output (during the whole session) as i do in Putty.
In Putty i can do easy "Copy All to clipboard" or enable session logging to a local file.
Is in WebTerminal maybe also such a functionality ?
Regards
21 REPLIES 21
Stephane_Grosj1
I _think_ it's available since day 1, but not documented afaik.
Please be aware - chrome works well, firefox currently not.
This problem is hopefully fixed in near future version.
(IE not tried)
Actually, it's as common as Ctrl-C/Ctrl-V. SecureCRT uses that, Linux shells...
Ctrl+Ins / Shift+Ins
Ok that works, would never tried shift+insert
Thanks
