Network Design Selection for a pair of BD8810 & SUMMIT X460 stack.
  • Question
  • Updated 2 years ago
  • Answered
I have a pair of BD8810 as CORE and Several stacks of SUMMIT X460 at floors of a multi-story building.
From each floor Stack two fiber uplinks are going to CORE Switches.
Please guide me which Protocol Should I use?
MLAG with VRRP, MLAG ESRP, VRRP-STP, EAPS-ESRP .
Application VoIP, Wifi controller & Data.
Please suggest me the Design for network.
Photo of Jitendra Patel
Jitendra Patel
  • 402 Points 250 badge 2x thumb
Posted 3 years ago
Photo of andreas
andreas
  • 1,218 Points 1k badge 2x thumb
Mlag for this setup. Great utilisation and you could dual Connecticut APs and clients IF needed.
Jitendra Patel
OK.. Thanks . What about L3/Gateway redundancy? What should I use VRRP or ESRP?
Is there any application note for such setup?
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,552 Points 10k badge 2x thumb
I'd go for VRRP, and eventually in Active/Active. Protect the edge with ELRP, use LACP between the Core and the stacks. Eventually add ELRP as well on the Core, using 16.1 new capabilities, to help prevent further loop creation even on the Core. You may want to add alternate path protection with MLAG.
Jitendra Patel
Configured VRRP in CORE BDs and MLAG. Configured LACP between CORE and Access Stack.
But some VLANs are blocked at CORE.. PFA Topology. Please guide..
Photo of Prashanth KG
Prashanth KG, Employee
  • 5,300 Points 5k badge 2x thumb
Hi Jitendra,
Can you please eloborate more on some VLANs are blocked at core? We need to make sure that all the VLANs are allowed in the ISC link (interconnecting CORE A and CORE B).
Keep us updated.
Photo of Ted
Ted
  • 1,174 Points 1k badge 2x thumb
I've had this topology for some time and I'm read to secure east west traffic.  I'm assuming I'll need to build a distribution layer.  I'm having trouble finding network diagram examples.  Please pass them along.
Thank you
