Network Load Balancing in summit X460-24x
Regulo_Perez
Device: Summit X460-24x
ExtremeXOS version 15.4.1.3
NLB configuration.
It is being made to integrate a VMware virtualized system which used Network Load Balance, I use LACP main ports of group 1: 2 to 1:12
enable sharing 1:2 grouping 1:2, 1:4, 1:6, 1:8 algorithm address-based L2 lacp
enable sharing 1:12 grouping 1:12-14, 1:16 algorithm address-based L2 lacp
The IP 192.168.206.95 NLB server associated with the multicast address
## Module fdb configuration.
create fdbentry 03: bf: c0: a8: ce: 5f vlan "Servers" port 1: 2, 1: 12
iparp configure add 192.168.206.95 Default vr VR-03: bf: c0: a8: ce: 5f
The need is that from the VLANS to access the server IP 192.168.206.95
configure vlan CuartoPiso add ports 1:9, 2:3 tagged configure vlan CuartoPiso add ports 2:23 untagged
configure vlan PlantaBaja add ports 1:2, 1:12, 2:3 tagged
configure vlan PlantaBaja add ports 1:1 untagged
configure vlan PrimerPiso add ports 1:2, 1:12, 2:3 tagged
configure vlan PrimerPiso add ports 1:3 untagged
configure vlan QuintoPiso add ports 1:2, 1:12, 2:3 tagged
configure vlan QuintoPiso add ports 1:11 untagged
configure vlan SegundoPiso add ports 1:2, 1:12, 2:3 tagged
configure vlan SegundoPiso add ports 1:5, 2:13 untagged
configure vlan Servidores add ports 1:1, 1:3, 1:5, 1:7, 1:9-11, 2:3 tagged
configure vlan Servidores add ports 1:2, 1:17, 1:22, 2:5, 2:7-12, 2:14-22, 2:25-26, 2:30-31, 2:33, 2:35-37, 2:41, 2:48 untagged
configure vlan TercerPiso add ports 1:2, 1:12, 2:3 tagged
configure vlan TercerPiso add ports 1:7 untagged
configure vlan Wifi add ports 1:1-3, 1:5, 1:7, 1:9, 1:11-12, 2:3 tagged
configure vlan Wifi add ports 2:27-28 untagged
I have received referrals from some documents that I have not been successful, I hope I can give some suggestions
2 REPLIES 2
Stephane_Grosj1
Are you speaking of Microsoft's NLB? That looks like it, but I want to make sure.
This switch is pure L2, or is it doing the L3 part as well? The config snippet doesn't show the routing config, but you are resolving the ARP on it, so that's ambiguous.
