Network Speed V2110
  • Question
  • Updated 3 years ago
  • Answered
Hello,
we have V2110 virtual wlan controllers running on VMWARE ESX. Does anybody know, what network speed the virtual interfaces of the controllers are running? Adapter type in the machine settings is vmxnet3. Windows machines showing 10 GB as network speed.
Is there such a tool as mii-tool available on the controller to show, what speed they are doing?
Thanks in advance, Ralf
Photo of Ralf
Ralf
  • 270 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,476 Points 5k badge 2x thumb
Hi Ralf
If you take a look in reports > controller status > system information the port speed is reported:
- ESA0 Interface:
    Interface State: up, 10000Mbps full duplex
- ESA1 Interface:
-Gareth
Photo of Ralf
Ralf
Thank you, that ́s it!
Ralf
Thanks for the feedback Ralf.
I created this article in our knowledgebase for future reference: https://gtacknowledge.extremenetworks.com/articles/Q_A/How-do-you-find-the-physical-port-speeds-on-an-IdentiFi-controller
Best regards
-Gareth
