Network View Wing 5.8.5
  • Question
  • Updated 2 months ago
  • Answered
  • (Edited)
looking at the the network view in wing 5.8.5 I can see the AP's OK, but some are RED with a red ring round them
I have looked on the help, but it does not give any information, does anyone have an idea why some are red ?
Photo of Phil storey
Phil storey
  • 1,254 Points 1k badge 2x thumb
Posted 1 year ago
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 5,554 Points 5k badge 2x thumb
Hello Phil,
this usually means those have a crash file on them.
Once you delete this (and commit & write to apply changes), it will look normal.
Regards,
Ondrej
Phil storey
Hi Ondrej
    many thanks for that, spot on, I'll keep an eye on those devices to see if crash files come back, But I think it may have been the power outage that we had
Photo of Tuan Nguyen
Tuan Nguyen
  • 678 Points 500 badge 2x thumb
Dear @Ondrej Lepa
I have more crash file. How to delete all them quickly? Why is there so much crash files
Thanks
Hi Tuan,
either use below process as described by Phil, or use CLI to do the batch remove as shown here
or using controller's GUI
See also article on our GTAC Knowledge database
Regards,
Ondrej
Phil storey
Hi Tuan
    I think you have to go to each device, if you go to Devices / operations and then select the device from the lefthand view then in the middle view
the crash file will appear under filename, highlight it and select delete at the bottom, Some on the crash files I had were from 2016, so filed them in B1N
Photo of Christopher Frazee
Christopher Frazee, Employee
  • 1,862 Points 1k badge 2x thumb
The steps outlined by Ondrej, using the CLI from the wireless controller, is the best and quickest method to remove all crash files from all devices within the rf-domain. If multiple rf-domains are configured, the remote-debug command would need to be issued for each rf-domain.
Photo of Joffre Flores
Joffre Flores
  • 70 Points
Perfecto me funciono por lineas de comando mas rapido
