New "Initial Configuration and Setup" Guide for 200 Series
  • 3
  • Article
  • Updated 6 months ago
Are you new to the 200 Series switches? Need some help doing initial setup and configuration for the software?
We've collected some of the most common configuration tasks into a how-to guide, ExtremeSwitching 200 Series: Initial Configuration and Setup. It's available now on the Extreme website.
If you have suggestions about additional topics to include in the guide, give me a shout.
Larry Kunz
Information Development
Extreme Networks
Photo of Larry Kunz
Larry Kunz, Employee
  • 1,274 Points 1k badge 2x thumb
Posted 11 months ago
  • 3
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Thank you Larry. That is a very nice reference!
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,024 Points 20k badge 2x thumb
if that should help during initial config it might help it the document includes the baudrate for the console port.
BTW, in the admin guide the factory baudrate is listed with 115200 which is wrong.
(Edited)
page#51
Baud Rate (bps) Select the default baud rate for the serial port connection from the menu. The factory default is 115200 baud.
Photo of Larry Kunz
Hi, Ronald. I checked with the 200 Series software lead and he confirmed that the default baud rate is 9600 bps,  as indicated in the Hardware Installation Guide.
If your customer isn't seeing that, and you'd like to discuss it further, let me know.
Per your suggestion that I should add the baud rate to the Initial Configuration and Setup Guide -- thanks for the good idea. I'll add it in the next revision.
Larry Kunz
Extreme Networks
lkunz@extremenetworks.com
Hi Larry,
I see the 9600 baud on my switch as the default but the "ExtremeSwitching 200 Series: Administration Guide" has the wrong information in it on page#51....
https://documentation.extremenetworks.com/200_admin/downloads/200_Series_Admin_Guide.pdf
-Ron
Photo of Larry Kunz
Ah, thanks! I'll get that corrected in the Administration Guide.
