New wireless AP's join the secondary (availability) controller?
  • Question
  • Updated 1 year ago
  • Answered
It seems like ever since I created an availability pair, any new AP's I add are being added to the secondary controller.
Perhaps I shouldn't care. Because it works okay. But I would rather keep all of my AP's on one controller unless there is a situation where they need to shift to the secondary controller.
Am I doing something wrong that they are finding the secondary and joining it?
AP's are 3825's and the firmware is 10.31.01.0048
Photo of Steve Ballantyne
Steve Ballantyne
  • 5,692 Points 5k badge 2x thumb
Posted 1 year ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 47,434 Points 20k badge 2x thumb
How do the APs dicover the controller - same subnet, DHCP option, DNS.
I'd just disable AP registration on #2 and all should register on #1.
GUI > AP > Global > Registration > Security Mode > Allow only approved Wireless APs to connect
Cheers,
Ron
(Edited)
Steve Ballantyne
Hey, thanks! That's an easy solution I hadn't thought of.
Also the move function is working great in case the AP is on the wrong controller.
On #2 go to > AP > APs > set checkmark on the AP that you'd like to move > Actions > approve as foreign.
It will take only a moment and the AP is now local to #1.
Steve Ballantyne
I was actually trying to take that route and it didn't seem to be working. But I was doing it backwards. I was on the second controller, and was approving it as "local". I just had the context wrong.  :-) Approve as foreign moved it right away.
