Newb Stacking question
  • Question
  • Updated 6 months ago
  • Answered
Hi all,
I have a question regarding stacking. We purchased 3 X450e-48p switches off of EBay, and I want to stack them. I found an article indicating that all of the switches had to be the same license level, EXOS Version and Active Partition. Two of the three are at the same license level (Advanced Edge) and are running the same EXOS version - in the active partition anyway, the third license level is Edge, and its running a newer EXOS version. Will they still stack? If not, can i copy the EXOS firmware from one to the other? If so, how?
Any advice would be appreciated.
Thanks,
David
Photo of David Gardner
David Gardner
  • 240 Points 100 badge 2x thumb
Posted 7 months ago
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,592 Points 3k badge 2x thumb
Hi David,
In order for the switches to be master capable, they have to have the same license level. I'd recommend to have the two switches with Advanced Edge as Master/Backup and then the third to just be the Standby node.
The image can't be copied from switch to switch as it doesn't have a TFTP server on it, just a TFTP client. Also the image isn't stored in an uncompressed/installable format on the switch.
Thanks
Brad
David Gardner
Drew,
These are not G2 switches, so unfortunately, I cannot upgrade past EXOS 15.3.
Thanks anyway for the suggestion.
David
Photo of Drew C.
Drew C., Community Manager
  • 40,056 Points 20k badge 2x thumb
I was posting it here in case others find this thread in the future.
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
Hello David,
If you follow the directions to get them to see each other and do the easy stacking they should stack together. However, I would position the switch with the lower license level and different exos version as the lower switch. Essentially forcing it to be slot 3. The switch will most likely come up as failed under the "show slot" command. From here you can run the "synchronize slot 3" command and it will push the images from the master to slot 3. Slot 3 will go down for this time and it will take about 15 minutes. If the slot 3 comes back and it is still failed you can configure the master-capability for lost 3 from the master and turn it off.
"configure stacking slot 3 master-capability off"
"reboot slot 3"
The license levels only have to match on master-capable switches. Slot 3 will never be able to become master or backup but it will function normally in the stack.
I hope this helps and let me know if you have any questions.
Photo of John Romero
John Romero
  • 310 Points 250 badge 2x thumb
I believe the firmware version 21.x.x.x comes with the advanced edge license now, there is no need to purchase it anymore.
David Gardner
Patrick,
I ran through the steps and sure enough, slot 3 failed. I ran the synchronize command on it, and slot 3 now says "Present" instead of failed, and running show slot 3 indicates Last Error: License mismatch. Also, the Management LED on the front panel is off instead of blinking. I assume that this is normal for this config?
Regarding John's comment about the firmware version, is it readily available, and what advantage would there be in upgrading - aside from getting the third switch on the same license level?
Thanks,
David
John Romero
We use the routing and OSPF functions that come with the upgrade
Hi David,
Run a "show stacking" and then grab the mac address for node 3. Then run the command "configure stacking node-address <mac> master-capability off" then "reboot node-address <mac>" this will force the slot 3 unit to turn off master capability. It should then join the stack.
The X450e isn't compatible with anything above EXOS 15.3, so not able to upgrade.
Thanks
Brad
David Gardner
Brad,
Did as you instructed, now the Management LED is flashing amber and slot 3 State is "Present" instead of "operational" and Current State is Fail: License Mismatch
David
David Gardner
It's also missing a bunch of info when I run Show Slot 3 - Download % is 0, S/N is blank, Node MAC is all 00
Image selected, primary and secondary version all blank as well.
Patrick Voss, Alum
Can you send:
"show stacking"
"show stacking configuration"
"show slot"
From the master in the stack.
David Gardner
Slot-1 Stack.1 # show stacking
Stack Topology is a Ring
Active Topology is a Ring
Node MAC Address    Slot  Stack State  Role     Flags
*00:04:96:36:ba:48  1     Active       Master   CA-
 00:04:96:51:da:52  2     Active       Backup   CA-
 00:04:96:36:1f:fe  3     Active       <none>   CA-
* - Indicates this node
Flags:  (C) Candidate for this active topology, (A) Active Node
        (O) node may be in Other active topology
Slot-1 Stack.2 #
Slot-1 Stack.3 # show stacking configuration
Stack MAC in use: 02:04:96:36:ba:48
Node               Slot         Alternate          Alternate
MAC Address        Cfg Cur Prio Mgmt IP / Mask     Gateway         Flags     Lic
*00:04:96:36:ba:48 1   1   Auto <none>             <none>          CcEeMm--- --
 00:04:96:51:da:52 2   2   Auto <none>             <none>          CcEeMm--- --
Flags:  (C) master-Capable in use, (c) master-capable is configured,
        (E) Stacking is currently Enabled, (e) Stacking is configured Enabled,
        (M) Stack MAC in use, (m) Stack MACs configured and in use are the same,
        (i) Stack MACs configured and in use are not the same or unknown,
        (N) Enhanced protocol is in use, (n) Enhanced protocol is configured,
        (-) Not in use or not configured
License level restrictions: (C) Core, (A) Advanced edge, or (E) Edge in use,
        (c) Core, (a) Advanced edge, or (e) Edge configured,
Slot-1 Stack.3 #
Slot-1 Stack.3 # show slot
Slots    Type                 Configured           State       Ports
Slot-1   X450e-48p                                 Operational   50
Slot-2   X450e-48p                                 Operational   50
Slot-3   X450e-48p                                 Empty         50
Slot-4                                             Empty          0
Slot-5                                             Empty          0
Slot-6                                             Empty          0
Slot-7                                             Empty          0
Slot-8                                             Empty          0
Slot-1 Stack.4 #
David Gardner
Any thoughts on what to do next? If I can't upgrade the license level on the one switch, can I downgrade the other two to just "Edge"? If that would make creating a stack easier, then I am okay with that, Just need to know how.
Patrick Voss, Alum
That is interesting. It looks like slot 3 is active in the stack (without a role) but missing in the "show slot" output. Was slot 3 removed at any point while grabbing these outputs? Can you trey rebooting the entire stack?
There is a way to downgrade the license for the entire stack to edge using the command:
"configure stacking slot <slot number> license-level edge"
David Gardner
Results after rebooting stack:
Slot-1 Stack.8 # show stacking
Slot-1 Stack.7 # show stacking configuration
 00:04:96:36:1f:fe 3   3   Auto <none>             <none>          --EeMm--- --
Slot-1 Stack.9 # show slot
Slot-3   X450e-48p                                 Failed        50
Slot-4                                             Empty          0
Slot-5                                             Empty          0
Slot-6                                             Empty          0
Slot-7                                             Empty          0
Slot-8                                             Empty          0
Slot-1 Stack.10 # show slot 3
Slot-3 information:
     State:               Failed
     Download %:          0
     Last Error:          License Mismatch
     Restart count:       1 (limit 5)
     Serial number:       N/A(0) N/A(0)
     Hw Module Type:      X450e-48p
     Configured Type:
     Ports available:     50
     Recovery Mode:       Reset
     Node MAC:            00:00:00:00:00:00
     Current State:       FAIL (License Mismatch)
     Image Selected:
     Image Booted:
     Primary ver:
     Secondary ver:
     Config Selected:     NONE
Is there any potential pitfalls in downgrading the license on the other two switches, or will this likely solve my problem?
David Gardner
Downgrading the license on the 2 and rebooting the stack made it all come up operational. Thank you everyone for your assistance.
