NGH 2.0 (hotspot 2.0) AP 3865 ds interoperability
  • Question
  • Updated 2 years ago
  • Answered
The line of products WS2110-9 and AP3865-DS are compatible with NGH2.0 (hotspot 2.0) standard?
Photo of Marco Garcia
Marco Garcia
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,114 Points 50k badge 2x thumb
Hotspot 2.0 was introduced with version 10.01.
If you have that min. version  installed you'd configure/use it.
Photo of Alexandr P
Alexandr P, Embassador
  • 12,670 Points 10k badge 2x thumb
Hi!
802.11u is supported by software (not hardware) so you have to look is v.10 controller's software support 38xx APs or not.
Photo of Paulo Francisco
Paulo Francisco, Employee
  • 1,534 Points 1k badge 2x thumb
Yeas, as mentioned by Ronald, Hotspot 2.0/Passpoint was introduced with v10.01. AP39xx are WiFi Alliance Passpoint certified. AP3865 are not certified (as they had been WiFi certified at an earlier release when feature was not available) but implement the exact same functionality that has been certified. I.e. While the AP3865e model has itself not  been certified, it is running the exact same certified firmware  that was certified on the AP3965.
Marco Garcia
Thanks Paulo Francisco, Ronald and Alexandre.
