NMS-ADV and EAC/Application Analytics virtual instances limit
  • Question
  • Updated 2 years ago
  • Answered
Hello,
what is the actual limit of EAC virtual instances and Application Analytics virtual instances that can be installed after buying single NMS-ADV license?
Kind regards,
Tomasz
Photo of Tomasz
Tomasz
  • 242 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Mike Thomas
Mike Thomas, Employee - GTAC - NMS
  • 7,498 Points 5k badge 2x thumb
Hi Tomasz,
Are you asking the maximum number of appliances? One Extreme Management Center server currently supports up to six appliances.
Photo of Tomasz
Tomasz
Ok, as many EAC appliances as one'd like (w.r.t. EMC management limit). Does this also apply to Application Analytics appliances? I couldn't spot this in the docs.
Regards,
Tomasz
The current maximum is 6 Analytics appliances, and 3M flows total for the total Extreme Management Center (Netsight) system.
see also
https://gtacknowledge.extremenetworks.com/articles/Q_A/How-many-Purview-appliances-can-I-add-in-my-N...
(Edited)
Photo of Tomasz
Tomasz
Ok, thank you. I might have introduced too much noise here maybe because of my English. So I can tell the VAR he can just deploy another virtual appliance with no additional cost.
Many thanks,
Tomasz
Correct, on both appliances, they are limited by the licenses generally applied to the EMC or Netsight Server, not the appliances themselves.
There are some exceptions, but generally the model follows this. They should be using the EMC server license, and the EMC server should have end station and flow count licenses applied to them.
The current limit for the Analytics engines is six. There has not been a lot of requests for more appliances. There is also a limit to the maximum number of flows a EMC server can handle. That is 3M flows.
