NMS Alarm to disable port
LeoP1
Contributor
Is there any way to make NMS disable a port on a SecureStack switch on event of na alarm?
I have a customer with lots of issues with Siemens IP Phones that simply die and put the connected VLAN in trouble. The dying-IP-Phone problem is physical, and in a simple show port inlinepower, the affected port shows the status as Overload.
The switch can send traps to the NMS, but the customer would like to rise na alarm (to dispatch support technicians) and immediatly disable the affected port.
Any ideas?
B
0 REPLIES 0
