NMS license installation.
  • 2
  • Question
  • Updated 3 weeks ago
  • Answered
Hi Extreme Networks,
I already installed the nms in our server.
Can I install it again and use the license key in another 1 server for the purpose of back up?
Thanks,
Resolut1on
Photo of Resolut1on
Resolut1on
  • 836 Points 500 badge 2x thumb
  • Sad
Posted 9 months ago
  • 2
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,824 Points 5k badge 2x thumb
Hi.
If you have NMS-ADV license then you are entitled to do so = you can use Primary, Backup, Lab installations.
Regards
Z
Photo of Resolut1on
Resolut1on
Hi Sir,
We just have NMS base license. Is it also transferable to another server?
Thanks,
Resolut1on
Photo of Lakshmi Narayan
Lakshmi Narayan
  • 90 Points 75 badge 2x thumb
can you find this key <license key removed by moderator> is active or not and for how many day
(Edited)
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,922 Points 20k badge 2x thumb
A license key for NMS has no real expiration date - you'd need a new update license if you for example upgrade from v7 to v8.
In that case you are only eligible to upgrade the license key with a valid service contract for the NMS.
You'd check with whoever sold you the software or contact the GTAC.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-contact-Extreme-Networks-Global-Tec...
Photo of Bin
Bin, Employee
  • 5,372 Points 5k badge 2x thumb
Photo of Resolut1on
Resolut1on
This is noted. Thanks Bin,
