Nms v8 one fabric connect missing with eval Lic
Andre_Brits_Kan
Contributor II
We are testing NMS v8 adv at a client. We have loaded the eval license. It would see that the connect tab is missing with the eval license. If i look at a client with a purchased licsense we do see the connect tav How do i access the connect tab?
4 REPLIES 4
Ryan_Yacobucci
Hello,
Please restart the NetSight server service:
service nsserver restart
The OFC services do not immediately start after being licensed, so on new installs the server needs an additional restart to get the service to show up.
Thanks
-Ryan
Ronald_Dvorak
Honored Contributor
You'd also try to clear the browser cache
Ronald_Dvorak
Honored Contributor
You'd try the direct link....
https://:8443/OneView/view/Connect
-Ron
Kurt_Semba
I just did the same and the Connect tab was missing as well. I had to restart the server service once to make the Connect tab appear:
does this help?
