no applications in dashboard
  • Question
  • Updated 3 years ago
  • Answered
Photo of Danilo Reyes
Danilo Reyes
  • 240 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Hernandez, Joshua
Hernandez, Joshua, Employee
  • 1,564 Points 1k badge 2x thumb
Hello Danilo,
Can you be more specific on your request?
Danilo Reyes
hi
thank for you reply
Danilo Reyes
all was working fine, but after i try  enable nac,  the purview give me this problem
Danilo Reyes
i think find my error i have  the comand export-destination twice.
set netflow export-destination x.x.x.x 2055
set netflow export-destination y.y.y.y 2055
how delete the first, i don ́t find the cli for delete it
Danilo Reyes
i find the cli command
clear netflow export-destination x.x.x.x
Photo of Thomas, Ken
Thomas, Ken, Alum
  • 4,368 Points 4k badge 2x thumb
Hi Danilo, it sounds like you may have this issue resolved now based on the above. Let us know if you have any further questions around this topic
Danilo Reyes
Hi
the problem is not resolved
do you have some idea ?
i dont understand why the applications information is not visible
Danilo Reyes
i can see location report, flow report, but not applicactions report.in application flow don ́t  appears information about the application
Danilo Reyes
Danilo Reyes
application tree map report
Danilo Reyes
aplication flow
Photo of Dudley, Jeff
Dudley, Jeff, Employee
  • 914 Points 500 badge 2x thumb
Hi Danilo,
My name is Jeff Dudley and I work in the GTAC.
We may have a complicated root cause here and I would like to create a service ticket for you and work the issue from there.  Would it be OK for you to provide an email address I can use to create the ticket with?
Thanks and regards.
Photo of Jeff
Jeff
  • 414 Points 250 badge 2x thumb
What was the solution to this? I am experiencing the same issue on a new install.
Thanks in advance,
Jeff
Photo of Jeff
Jeff
I think I got it. I pointed the remote of the gre tunnel to the switch ip address and not the tunnel address.
Photo of Gabriel Queiroz
Gabriel Queiroz
  • 60 Points
What do you mean with "switch ip address" and "tunnel address"?
I am experiencing the same issue on a new install here. Now I have this:
interface loop.0.1  ip address 172.100.0.1 255.255.255.0 primary
  no shutdown
interface tun.0.1  tunnel destination 192.168.168.153
  tunnel mode gre l2 ge.1.11
  tunnel mirror enable
  tunnel source 172.100.0.1
  no shutdown
In the tunnel interface, the 192.168.168.153 is the Purview IP address, and the source is the loopback interface from the switch.
You can also check my netflow config:
# netflow
set netflow export-interval 1
set netflow export-destination 192.168.168.153 2055
set netflow export-version 9
set netflow port lag.0.1-5 enable rx
set netflow port ge.1.1-8,27,45 enable rx
set netflow template refresh-rate 30 timeout 1
set netflow cache enable
We also activated "Collect Interface Statistics" in all physical and logical ports.
