Noisy Fans
  • Question
  • Updated 3 years ago
  • (Edited)
One of our 440-48 switches has a pretty noisy fan. Does anyone know if this is field replaceable?
Photo of Sheldon Lefkowitz
Sheldon Lefkowitz
  • 110 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Hi Sheldon,
The X440 does not have field replaceable fans. If it is excessively loud, I would suggest opening a case with GTAC to troubleshoot the fan issues.
-Brandon
Photo of Tooley, Akiko
Tooley, Akiko, Employee
  • 600 Points 500 badge 2x thumb
Hello,
Please refer to the X440 datasheet: Fan Speed and Acoustic Noise: http://learn.extremenetworks.com/rs/extreme/images/Summit-X440x-DS.pdf
Has the noise increased over time?
It is optional to do a dB(A) test to verify the noise level.
Sheldon Lefkowitz
Noise has now sort of backed down. I'm planning on climbing up to the mount and see if a little air blowout will help....maybe it's just a lot of dust gathered in there.
