Not able to communicate between platforms via X440-8t switch
  • Problem
  • Updated 3 years ago
  • Solved
  • (Edited)
I have 2 Linux devices with ip address 192.168.1.5 and 192.168.1.7
and a VM(virtual machine) with ip address 192.168.1.30.
Can you please provide the configurations to communicate the Linux devices to VM through
the X440-8t switch?
Currently I have connected VM port  to Management port and able to communicate
management port with VM.
ping vr vr-mgmt 192.168.1.30
Ping(ICMP) 192.168.1.30: 4 packets, 8 data bytes, interval 1 second(s).
16 bytes from 192.168.1.30: icmp_seq=0 ttl=64 time=0.939 ms
--- 192.168.1.30 ping statistics ---
4 packets transmitted, 4 packets received, 0% loss
round-trip min/avg/max = 0/7/9 ms
But I am not able to communicate Linux devices with VM.
* X440-8t.3 # show vlan
Name            VID  Protocol Addr       Flags                       Proto  Ports  Virtual
        Active router
        /Total
Default         1    --------------------------------T--------------- ANY    1 /12  VR-Default
Mgmt            4095 192.168.1.10   /24  ---------------------------- ANY    1 /1   VR-Mgmt
Total number of VLAN(s) : 2
* X440-8t.4 # show switch
SysName:          X440-8t
SysLocation:
SysContact:       support@extremenetworks.com, +1 888 257 3000
System MAC:       00:04:96:97:7C:27
System Type:      X440-8t
SysHealth check:  Enabled (Normal)
Recovery Mode:    All
System Watchdog:  Enabled
Current Time:     Thu Nov  5 23:35:24 2015
Timezone:         [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
Boot Time:        Thu Nov  5 21:53:18 2015
Boot Count:       15
Next Reboot:      None scheduled
System UpTime:    1 hour 42 minutes 6 seconds
Current State:    OPERATIONAL
Image Selected:   primary
Image Booted:     primary
Primary ver:      15.3.1.4
                  patch1-19
Secondary ver:    15.3.1.4
Config Selected:  primary.cfg
Config Booted:    primary.cfg
primary.cfg       Created by ExtremeXOS version 15.3.1.4
                  87856 bytes saved on Thu Nov  5 19:14:04 2015
regds,
Biju
Photo of biju das
biju das
  • 100 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Frank
Frank
  • 3,662 Points 3k badge 2x thumb
I don't think you can make the management port talk with any of the other ports - it's completely separate.
I would give the management port a different IP (just for clarity), plug the VM and the two Linux servers into the regular ports, and see if that helps.
   Frank
Photo of biju das
biju das
OK Thanks. Now I am able to communicate with VM and Linux device.
regds,
Biju
