Not able to create vrrp in X460-48t summit switch
  • Problem
  • Updated 8 months ago
  • Solved
X460-48t.3 # show version
Switch      : 800538-00-10 1515N-43544 Rev 10.0 BootROM: 2.0.2.3    IMG: 15.5.3.4
PSU-1       : PSSW301201A -02 800519-00-06 1512A-40004
PSU-2       : PSSW301201A -05 800519-00-06 1710A-40145
Image   : ExtremeXOS version 15.5.3.4 v1553b4 by release-manager
          on Fri Nov 7 12:56:24 EST 2014
BootROM : 2.0.2.3
Diagnostics : 6.3
X460-48t.4 #
Below is part of where the issue is...
# Module vsm configuration.
X460-48t.3 #
X460-48t.3 #
X460-48t.3 # create vrr
%% Invalid input detected at '^' marker.
X460-48t.3 # enablr
X460-48t.3 # enable vrr
You can see the list of command available for VR.
X460-48t.3 # enable
  access-list           Access list
  auto-provision        Allow switch to obtain the IP Address, Gateway, Config file via DHCP
  bfd                   BFD specific settings
  bootp                 Configure BOOTP client
  bootprelay            Configure BOOTP Relay service
  cdp                   Cisco Discovery Protocol (CDP)
  cfm                   IEEE 802.1ag - Connectivity Fault Management
  clear-flow            CLEAR-Flow agent
  cli                   Command Line Interface settings
  cli-config-logging    CLI command logging
  clipaging             Display command output one screenful at a time
  cpu-monitoring        Monitor system/process cpu utilization
  dhcp                  Configure DHCP client
  diffserv              diffserv
  dos-protect           automatic denial-of-service protection
  dot1p                 dot1p
  eaps                  EAPS (Ethernet Automatic Protection Switching) domain
  edp                   EDP
  elrp-client           ELRP (Extreme Loop Recovery Protocol) Client
  elsm                  ELSM (Extreme Link Status Monitoring)
  erps                  Ethernet Ring Protection Switching (ITU-T G.8032)
  esrp                  ESRP (Extreme Standby Router Protocol) Domain
  ethernet              Ethernet OAM
  fdb                   Configure FDB related parameter
  fip                   FCoE Initialization Protocol
  flooding              flooding
  flow-control          Pause frame handling
  icmp                  icmp option
  identity-management   Identity Management
  idletimeout           Timeout for idling configuration session
  igmp                  Internet Group Management Protocol
  ip-fix                Enable IPFIX module
  ip-option             ip option
  ip-security           IP Security
  iparp                 ip arp command
  ipforwarding          IP forwarding
  ipmcforwarding        IP Multicast Forwarding
  iproute               IP routing module
  irdp                  ICMP Router Discovery Protocol
  jumbo-frame           jumbo-frame
  learning              learning
  led                   LED display functions
  license               license or feature pack
  lldp                  Configure LLDP specific settings
  log                   Configure log service
  loopback-mode         loopback
  mac-lockdown-timeout  mac lockdown timeout
  mirror                Mirror feature configuration
  mlag                  Multi-switch Link Aggregation used to combine remote ports and local ports to a common logical connection
  mld                   Multicast Listener Discovery Protocol
  mvr                   Multicast VLAN Registration
  mvrp                  Multiple VLAN Registration Protocol
  neighbor-discovery    IPv6 neighbor
  netlogin              Network Login related commands
  ntp                   Network Time Protocol
  pim                   PIMv6 cache entries
  ports                 Physical ports
  radius                Radius Client
  radius-accounting     Radius Client Accounting
  rip                   RIP Routing
  ripng                 RIPng Routing
  rmon                  RMON CLI command
  router-discovery      IPv6 Router Discovery
  sflow                 Enable SFLOW module
  sharing               Load sharing
  smartredundancy       smart redundancy on a port(related to Software redundant port feature)
  snmp                  Enable SNMP
  snmpv3                SNMPv3
  sntp-client           Enable SNTP client
  stacking              Stacking
  stpd                  STP domain
  subvlan-proxy-arp     Configure sub-VLAN proxy ARP
  syslog                Configure syslog service
  tacacs                TACACS+ Client
  tacacs-accounting     TACACS+ Client Accounting
  tacacs-authorization  TACACS+ Client Cli Authorization
  tech-support          Technical support
  telnet                allow incoming telnet connections
  tunnel                tunnel
  udp-echo-server       UDP-Echo Server
  upm                   Universal port manager
  virtual-router        virtual router
  vlan                  VLAN configuration
  vm-tracking           Virtual Machine mac tracking
  vman                  Virtual Metropolitan Area Network
  vr                    virtual router
  watchdog              watchdog monitoring feature
  web                   Web access
  xml-mode              Raw XML configuration mode
  xml-notification      XML Notification Process
  <eapsDomain>          EAPS domain name
Photo of Sunday Orjingene
Sunday Orjingene
  • 90 Points 75 badge 2x thumb
Posted 9 months ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
Hello Sunday,
Can you show us the "show license" output?
Sunday Orjingene
* X460-48t.6 # show licenses
Enabled License Level:
        Edge
Enabled Feature Packs:
        None
* X460-48t.7 #
Sunday Orjingene
Thank you Patrick
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
The following URL shows features in our license modules on EXOS.
http://documentation.extremenetworks.com/FLR_16/EXOS_16_2/Feature_License_Requirements/r_advanced-ed...
