Not able to see Cookie Id on a Packet In on Extreme x440
  • Problem
  • Updated 11 months ago
  • Solved
  • (Edited)
We are running few VLANs in Hybrid mode (openflow enabled). But in the packet in that we get we are not able to see the cookie id.
Cookie Id is 0x00000000000000
Match field is just contains the port number
We were expecting the cookie id to match the non-zero cookie id on the flow and the matching condition.
We can see the packet counts going up on the flow so we know it is being activated.
Help please!
Version info:
Switch      : 800552-00-05 1520N-44732 Rev 5.0 BootROM: 1.0.2.1    IMG: 16.1.3.6
PSU-1       : Internal PSU-1 800592-00-05 1507A-45210
PSU-2       :
Image   : ExtremeXOS version 16.1.3.6 by release-manager
          on Thu Feb 4 13:10:10 EST 2016
BootROM : 1.0.2.1
Diagnostics : 3.1
Photo of Azahar Machwe
Azahar Machwe
  • 80 Points 75 badge 2x thumb
Posted 11 months ago
Photo of Ram
Ram, Employee
  • 1,450 Points 1k badge 2x thumb
Could you open a case and provide us the below requested outputs?
1. show openflow
2. show openflow controller
3. show openflow flows
4. show openflow groups
5. show openflow ports
6. show openflow ports <port number>
7. show openflow ports <port number> advertised
8. show tech
9. Where did you capture the packets to verify the cookie-id is not matching?
10. Is this cookie-id mismatch causing any issues with network traffic?
Azahar Machwe
Definitely will do that.
Photo of Chris Sargent
Chris Sargent
  • 70 Points
The case management website does not recognise any of the serial numbers of our switches and then sends us to a 404 page anyway.  Is there another way to create a ticket?
Serial numbers:  1520N-44732 or 1511N-4073
Photo of Ram
Ram, Employee
I have noticed the case got opened (Case# 01345117). One of our GTAC engineer will contact you shortly. Please login into extranet and attach the requested logs to this case.
Chris Sargent
  • 70 Points
I can see the case (and the duplicates that have since been closed).
However we cannot open it - we are just redirected to a page displaying "Error: invalid case".
FYI this is the URL of the link to the case:  https://extremeportal.force.com/ExtrCaseDetail?id=5003400000xGVWcAAO&lv=My+Open+Cases
Photo of Drew C.
Drew C., Community Manager
  • 37,320 Points 20k badge 2x thumb
Chris, I see this in the portal under your account and will let the portal team review.
If you have further issues, please start a new thread to discuss. This conversation is very different from the original question and I can't easily merge the comments at this point.
Photo of Thomas, Ken
Thomas, Ken, Alum
  • 4,368 Points 4k badge 2x thumb
Chris, very sorry that you faced this issue. It is an issue with getting user contact records associated to the proper account/company record in our systems, mostly for newly registered users. We are working on fixing your case record to get it updated to the proper account so that you can view it online.  I have updated your contact record to the proper account/company, so you will not have this issue going forward with your next cases, and your current case should be fixed shortly. When you have an urgent issue or if there is a problem with the online case management, you can always contact GTAC on the phone. Again, very sorry for the inconvenience.  I have written a knowledge article about the No Account Association issue which has some more details and a process for getting it resolved. I hope we have a better ,more proactive solution for this soon.
