Number of Licenses Required for EXOS Stack
  • Question
  • Updated 1 year ago
  • Answered
Hi I have 2 switches  x460-48t running on Core license and also in stack, i would like to add the 3rd switch  to the stack, however this switch is running on advanced edge license. How do i proceed ? as the customer doesn't want to go for the license restriction and the core licenses are not anymore available .
Thanks
Note: This conversation was created from a reply on: Number of Licenses Needed on Stack.
Photo of Pos123
Pos123
  • 112 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Alexandr P
Alexandr P, Embassador
  • 12,042 Points 10k badge 2x thumb
Hello!
You can configure switch with Adv Edge license as non-master-capable
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,016 Points 5k badge 2x thumb
The easiest way for this to be no problem is to just set the third switch as "not master capable" -  Do this by adding the switch and once in run the command "configure stacking <node address of the new #3 switch> master-capability off" -  reboot the slot and your good to go.
Bill
Photo of Pos123
Pos123
Thank you guys,
One more question :
will the  "configure stacking node-address <>  license-level  <> "   , still be applicable??
Or i just enable the license  on the switch using  "enable license {software} <key>" ?
BR
Photo of Alexandr P
  • 11,778 Points 10k badge 2x thumb
This is different commands.
"configure stacking node-address <>  license-level  <> " - it's for restrict licence-level for some node if desired license-level of stack is lower.
"enable license {software} <key>" - it's for install license or FP
Photo of Pos123
Pos123
yes, i know....if the 3rd switch comes with advanced edge license and the current stack is on CORE license restriction and the idea is to make this 3rd switch NOT a master capable , how to i load the license on this 3rd new switch ?
Photo of Alexandr P
You can install license as usual.
license-level restriction it's when you have stack nodes with for example Adv Edge license and you add new node with Core license.
"configure stacking [node-address node_address | slot slot_number] master-capability off" it's just for that node with lower license level don't become Master.
Photo of Pos123
Pos123
thank you
Photo of Mrxlazuardin
Mrxlazuardin
  • 1,454 Points 1k badge 2x thumb
How to specify which license is for which switch on EXOS Stack? For example, what should I do if I just want to upgrade only two master capable of same type stacked switches?
Best regards,
