OIDs for RF Quality Index
  • Question
  • Updated 1 week ago
Hello -
I'd like to track the RF Quality Index of my entire WiNG (VX9000) system and the same index per each RF Domain.  Is there an OID in the WiNG MIBs for this?
Thanks!
Photo of Max McGrath
Max McGrath
  • 172 Points 100 badge 2x thumb
Posted 1 week ago
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 3,564 Points 3k badge 2x thumb
I found these:
-- 1.3.6.1.4.1.388.50.1.4.3.2.6.1.1.19
wingStatsRfdWlClientStatDetailQIndex OBJECT-TYPE
SYNTAX Integer32
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"RF quality Index
Measure the quality of the medium in percentage. It is a function of average retries and error rate. Its range is from 0-100. Typically:
  -1: no data available ( e.g. radio is not in wlan operation mode )
  0-20: very poor quality
  20-40: poor quality
  40-60: average quality
  60-100: good quality
XPath: /wing-stats/rf_domain[name=key1]/wireless/client-stats-details[mac=key2]/q_index"
::= { wingStatsRfdWlClientStatDetailEntry 19 }
-- 1.3.6.1.4.1.388.50.1.4.3.2.5.1.1.20
wingStatsRfdWlClientStatQIndex OBJECT-TYPE
SYNTAX Integer32
STATUS current
DESCRIPTION
"RF quality Index
  20-40: poor quality
XPath: /wing-stats/rf_domain[name=key1]/wireless/client-stats[mac=key2]/q_index"
::= { wingStatsRfdWlClientStatEntry 20 }
-- 1.3.6.1.4.1.388.50.1.4.2.25.10.1.1.21
wingStatsDevWlRadioStatQIndex OBJECT-TYPE
SYNTAX Integer32
STATUS current
DESCRIPTION
"RF quality Index
  20-40: poor quality
XPath: /wing-stats/device[mac=key1]/wireless/radio-stats[radio_id=key2]/q_index"
::= { wingStatsDevWlRadioStatEntry 21 }
-- 1.3.6.1.4.1.388.50.1.4.3.2.9.1.1.21
wingStatsRfdWlRadioStatQIndex OBJECT-TYPE
SYNTAX Integer32
STATUS current
DESCRIPTION
"RF quality Index
  20-40: poor quality
XPath: /wing-stats/rf_domain[name=key1]/wireless/radio-stats[radio_id=key2]/q_index"
::= { wingStatsRfdWlRadioStatEntry 21 }
Max McGrath
Thank you.
That brought back an index per client.  But what I'm really looking to keep track of (for history/trending purposes) is the over RF Quality Index of either the entire system or on a per RF Domain basis....much like below.  A single digit score per RF Domain.
Thanks!
Photo of Andrew Blomley
Andrew Blomley, Employee
  • 282 Points 250 badge 2x thumb
I would recommend testing NSight, it is what the NSight was designed for.
https://documentation.extremenetworks.com/WiNG/5.9.0/9035124_NSight_5_9_UG.pdf
