OneView check for firmware updates only works for Enterasys gears?
  • Idea
  • Updated 2 years ago
  • Under Consideration
When I check firmware updates in OneView it only shows updates for Enterasys gears (S/A/B/C/G series and EWC controllers). But it does not show the updates for X430 and X440 devices even there are new versions on extranet. Is it not supported yet? Is it because OneView checks on extranet site but EXOS firmwares still hosted on esupport.extremenetworks.com?
Thanks
Rahman
Photo of Rahman Duran
Rahman Duran
  • 2,012 Points 2k badge 2x thumb
Posted 2 years ago
Photo of Yacobucci, Ryan
Yacobucci, Ryan, Multi-Tier Technical Support Engineer
  • 4,776 Points 4k badge 2x thumb
Hello,
Currently this feature is not supported. There is work being done internally to get this feature up and running, but it's not clear when this feature will be available.
Thanks
-Ryan
