Oneview switch connections - switches don't show link when using management port
  • Question
  • Updated 12 months ago
  • Answered
When looking at the network map in Oneview - switches don't show the link when using the management port - is there a way to have oneview display those links?
Photo of craymond
craymond
  • 608 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,908 Points 5k badge 2x thumb
The links are detected based on CDP (Exteme, Enterasys, Cabletron Proprietary), EDP, and LLDP.
As far as i know EXOS does not support LLDP or EDP in Management ports
Here is an detailed article on how the links are formed in OneView.
https://gtacknowledge.extremenetworks.com/articles/Q_A/How-do-MAP-views-from-OneView-create-links
In case if you would like to create manual links for management ports it is possible from EMC 8.0
Here is an article on how to create manual links between devices.
https://gtacknowledge.extremenetworks.com/articles/Q_A/Is-it-possible-to-create-manual-links-between...
I hope this helps!
