OSPF default gateway
  • Question
  • Updated 12 months ago
  • Answered
I need to understand the OSPF IProute output for the default route.
I have a network that basically has 4 exits to the internet  ( default routes )
If the switch see's these routes with the same metric ,  they all appear in the routing table ?
 If they are seen with different metrics then only the lowest metric is seen in the " show IP route" which is the current default gateway.
Is there a way of showing the " other default routes and their metrics.
Photo of Rod Robertson
Rod Robertson
  • 2,272 Points 2k badge 2x thumb
Posted 12 months ago
Photo of Parthiban V
Parthiban V, Employee
  • 608 Points 500 badge 2x thumb
    If the metrics are different only the lowest metric route will be displayed in the routing table. We cannot see the other higher metrics route in routing table.
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,616 Points 5k badge 2x thumb
The OSPF process sends the equal, lowest cost paths to rtmgr so we have the ability to do ECMP if it's enabled. If you dont have ECMP enabled you can see that only one path was provided to FIB.
